Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
python -m venv returns an error
Dennis__Harold
I recently installed the Intel distribution for python.
The following error occurs when attempting to create a virtual environment:
python -m venv ${HOME}/venv6
Error: Command '['/N/u/hbrokaw/Carbonate/venv6/bin/python', '-Im', 'ensurepip', '--upgrade', '--default-pip']' returned non-zero exit status 1.
Is there any information about what would cause this to occur and how I can fix it.
Cicada Dennis
[email protected]
Dennis__Harold
Well I figured out a solution, and Intel should really fix this, it is so easy.
I downloaded the Python source code. I built it. Then I copied the directory:
install_dir/lib/python3.6/ensure_pip/ to the intel distribution's install_dir/lib/python3.6
All Intel needs to do is add that directory and its contents to their distribution.
Dennis__Harold
Thanks. I have already installed virtualenv as a work-around on this issue. That does not, however, explain the error in this distribution. I installed the distribution as specified on the Intel site, and "out-of-the-box", so to speak, this function of python has this error. Is this error a known problem with the current linux version of the Python distribution?
Dennis__Harold
As additional info, the error returned is:
/N/u/hbrokaw/Carbonate/venv6/bin/python: No module named ensurepip
So the ensurepip is not present in the virtualenv when it tries to create pip. If one uses the --without-pip option, then the venv gets created.
This seems like a bug in the distribution.
Dennis__Harold
