Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
spawn_multiple with mpi4py on Windows
maartenb
新分销商 I
4,126 次查看
I'm trying to spawn multiple processes from python using mpi4py.
sub_comm = MPI.COMM_SELF.Spawn_multiple(["app.exe"]*nProcess,info=mpiInfo, args = args)
It fails because the root of my intel python distribution (C:\intelpython3\) gets prepended to the command.
[proxy:1:0@xxxx] HYD_spawn (..\windows\src\hydra_spawn.c:231): unable to run process c:\intelpython3/app.exe (error code 2)
[proxy:1:0@xxxx] launch_processes (proxy.c:603): error creating process (error code 2). The system cannot find the file specified.
I tried passing an info object with the "wdir" set to the location of "app.exe", but it didn't help. How can I prevent this?
Maarten
0 项奖励
1 解答
maartenb
新分销商 I
4,079 次查看
OK I solved it. Turning on debug information by setting environment variable I_MPI_HYDRA_DEBUG=on showed that there's another parameter in the MPI Info object called "path", which is set by default to the location of the python distribution. The wdir directory is assumed to be relative to this path. Setting it to the appropriate directory and passing it to Spawn_multiple() solved it.
mpiInfo = MPI.Info.Create()
mpiInfo.Set('path','path/to/set')
mpiInfo.Set('wdir','working/directory')
sub_comm = MPI.COMM_SELF.Spawn_multiple(["app.exe"]*nProcess,info=[mpiInfo]*nProcess, args = args)
在原帖中查看解决方案
0 项奖励
2 回复数
maartenb
新分销商 I
4,080 次查看
0 项奖励
RaeesaM_Intel
主持人
4,069 次查看
Hi Maarten,
Glad to know that your issue is resolved and thank you for sharing the solution as it will be beneficial for the community.We will no longer monitor this thread and please feel free to raise a new thread if you have any further queries.
Raeesa
0 项奖励
回复
