2020.2 deprecations
aag
I'm seeing 2020.2 had deprecated a number of APIs. While
https://docs.openvinotoolkit.org/latest/_docs_IE_DG_Extensibility_DG_CPU_Kernel.html
provides some guidance for layer implementation with the new API, I'm not finding a direct replacement to layer's parameters access, such as CNNLayer::GetParamAsFloat. What would be the API supposed to replace this?
In general, is there a guide somewhere on how to migrate a custom CNNLayer to the new API?
Thanks!
Ilya_C_Intel
In 2020.2 release CNNLayer API was deprecated. It means that at the current moment you shouldn't use CNNLayer API.
Instead of CNNLayer please use nGraph API. We have a documentation which describes how you can create custom nGraph operation: https://docs.openvinotoolkit.org/latest/custom_operations.html
The nGraph API doesn't contain methods like CNNLayer::GetParamAsFloat because this API uses another philosophy. Each attribute of each operation has strong typing
If you want to get some attribute from operation in your custom kernel, you should:
  • Cast nGraph::Node to known operation
  • get attribute from this operation using a special class method.
Here is an example from documentation: https://docs.openvinotoolkit.org/latest/_docs_IE_DG_Extensibility_DG_CPU_Kernel.html
Ilya
