6597 Discussions
Abort was called at 347 line in file: /opt/src/opencl/shared/source/os_interface/linux/drm_neo.cpp
SandeshKum_S_Intel
The following issue occurs while trying to run OpenVINO based inference on GPU device in Alder Lake platform.
Please find the below system details:
Kernel: 5.17.0-051700-generic x86_64
Distro: Ubuntu 20.04.6 LTS (Focal Fossa)
CPU: 12th Gen Intel Core i7-12700E
Graphics: Device-1: Intel driver: i915 v: kernel
Compute Runtime Version: intel-opencl-icd/now 22.35.24055+i815~u20.04 amd64[installed,local]
Aznie_Intel
Hi SandeshKum_S_Intel,
Thanks for reaching out.
I believe the issue is not related to OpenVINO and might be due to missing firmware in your system. The same issue was reported in compute-runtime Github repo and the issue is resolved by updating the Linux firmware. You may check out this GitHub repo for more details:
https://github.com/intel/compute-runtime/issues/566
Aznie
SandeshKum_S_Intel
Thanks for the response @Aznie_Intel
Is ubuntu 20.04 and kernel 5.17 supported for using GPU/OpenCL drivers on ADL systems ?
Can you provide any documentation for updating the Linux firmware ?
Aznie_Intel
Unfortunately, OpenCL and Linux firmware is not part of the OpenVINO toolkit. I would suggest you post your question in compute-runtime Github repo for further information.
Meanwhile, Ubuntu 20.04 and kernel 5.17 is a compatible operating system with OpenVINO. You may refer to our System Requirement.
Aznie
Aznie_Intel
This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Aznie
