Anti-spoof-mn3
Soheb
I’m evaluating anti-spoof-mn3 for a real-time presentation attack detection use case in an Android app and will be deploy on client devices. We will not modify the model only run inference on-device.
Could you please confirm the following?
  1. License & Commercial Use
    • Is the anti-spoof-mn3 ONNX model (weights) licensed in a way that permits commercial use in a closed-source Android app (e.g., MIT as stated in the repo/docs)?
    • Are there any additional restrictions (redistribution terms, attribution wording, NOTICE requirements) when bundling the unmodified weights in an app?
  2. Weights vs. Datasets
    • Were the released weights trained on datasets such as CelebA-Spoof (or others) that impose downstream usage restrictions?
    • If so, do those dataset licenses affect commercial redistribution/use of the resulting weights, or are the weights explicitly cleared for commercial use?
  3. Attribution & Notices
    • What exact attribution text and license files should we include in our in-app OSS notices?
    • Do you require a specific citation (paper/repo)?
  4. Compliance Extras (if any)
    • Any guidance on naming/branding usage, or patent considerations we should be aware of?
Soheb.
Wan_Intel
Hi Soheb,
Let me check with relevant team, and we will provide an update here at the earliest.
Wan
Zulkifli_Intel
Hi Soheb,
Thank you for your patience.
  •  Is the anti-spoof-mn3 ONNX model (weights) licensed in a way that permits commercial use in a closed-source Android app (MIT License in Legal Information)?
The model is released under the MIT License (stated in Legal Information).MIT License permits commercial use, redistribution, modification, and sublicensing.
Usual obligations: keep the copyright & license notice in redistributions. No restriction against closed-source Android apps.
anti-spoof-mn3 weights were trained on CelebA-Spoof and other open datasets (documented in model.yml).
  • If so, do those datasets licenses affect commercial redistribution/use of the resulting weights, or are the weights explicitly cleared for commercial use?
ANS: CelebA-Spoof itself has a non-commercial clause, but OpenVINO clarifies that released weights are cleared for commercial use (Intel handles licensing due diligence).
You need to include:
MIT License text (from the repo LICENSE file).
Attribution: “anti-spoof-mn3 model from Open Model Zoo (OpenVINO Toolkit)”
Citation (recommended but not strictly required): refer to the original paper + OpenVINO repo link.
No naming/branding restrictions, but don’t use Intel/OpenVINO trademarks as product branding.
No patent clauses are listed in MIT; you can use it at your own risk.
I hope these answers are enough for you.
Zul
Wan_Intel
Hi Soheb,
Thank you for your question.
We will proceed with closing this case as we have provided answers. If you need additional information from us, please submit a new thread.
Wan
