6584 Discussions
Any idea on how to fix MultiStick_GoogLeNet.py on NCSDK 2.05.00.02 ?
I have started out with
sys.path.insert(0, "../../ncapi2_shim")
import mvnc_simple_api as mvnc
but I can't get this to work ;
opt = devHandle[devnum].GetDeviceOption(mvnc.DeviceOption.OPTIMISATIONLIST) print("Optimisations:") print(opt) graphHandle.append(devHandle[devnum].AllocateGraph(graph)) graphHandle[devnum].SetGraphOption(mvnc.GraphOption.ITERATIONS, 1) iterations = graphHandle[devnum].GetGraphOption(mvnc.GraphOption.ITERATIONS) print("Iterations:", iterations)
If I comment out the lines above it will run "empty"
Any ideas on how to fix it under NCSDK 2.05.00.02 ?
