6595 Discussions
Anyone had a successful implementation of EfficientDet on Openvino
Konakanti__Kishore
I would like to know the success rate of EfficientDet on Openvino before going ahead to train EffDet on my custom dataset. Please let me know if any one had a a successful, both speed and accuracy wise, implementation.
Munesh_Intel
Hi Kishore,
EfficientDet topology is not supported by OpenVINO.
For your additional information, the following page, 'Get a Deep Learning Model Performance Boost with Intel® Platforms', contains benchmarks that demonstrate high performance gains on several public neural networks for a streamlined, quick deployment on Intel® CPU, VPU and FPGA platforms.
https://docs.openvinotoolkit.org/2020.3/_docs_performance_benchmarks.html
Munesh
Konakanti__Kishore
Munesh,
Thanks for the reply.
In my case, EfficientDet-d2 has promising results. I will look at other methods to reduce inference speeds.
Thank you,
Kishore
Munesh_Intel
Hi Kishore,
In that case, I would suggest you validate them on your end. Train your EfficientDet-d2 model in any of the supported framework and try optimizing using Model Optimizer.
More information is available at the following page:
https://docs.openvinotoolkit.org/2020.3/_docs_MO_DG_prepare_model_Prepare_Trained_Model.html
And do share the eventual results for the benefit of everyone in our OpenVINO community.
Munesh
Dmitry_K_Intel3
OpenVINO now supports EfficientDet. Please use master branch to convert a model to IR: https://github.com/openvinotoolkit/openvino/. Then 2020.4 or later release can work with this IR.
small tutorial: https://github.com/dkurt/openvino_efficientdet
