6595 Discussions
Arc A380 not detected in Docker on Linux, fallback to CPU, why?
PieterV
Hi, new to OpenVINO, trying to get hardware ML working with my ARC A380 on Proxmox 8 and Docker 29.
I first noticed the problem with the GPU not being detected when I tried out Immich.
To help troubleshoot I am now trying to get OpenVINO to work following these instructions.
I get the same error: Available devices for Open VINO: CPU
$ docker run --rm -it  --device=/dev/dri --group-add=$(stat -c "%g" /dev/dri/render* | head -n 1) -u $(id -u):$(id -g) -v ${PWD}/model:/opt/model -p 9123:9123 openvino/model_server:latest-gpu --model_path /opt/model --model_name resnet --port 9123 --tar
get_device GPU
[2025-11-30 16:40:39.639][1][serving][info][server.cpp:91] OpenVINO Model Server 2025.3.0.6e2e910de
[2025-11-30 16:40:39.639][1][serving][info][server.cpp:92] OpenVINO backend 2025.3.0.dev20250826
[2025-11-30 16:40:39.639][1][serving][info][pythoninterpretermodule.cpp:37] PythonInterpreterModule starting
Python version:
3.12.3 (main, Aug 14 2025, 17:47:21) [GCC 13.3.0]
Python sys.path output:
['', '/ovms/lib/python', '/ovms/python_deps', '/lib/python312.zip', '/lib/python3.12', '/lib/python3.12/lib-dynload']
[2025-11-30 16:40:39.710][1][serving][info][pythoninterpretermodule.cpp:50] PythonInterpreterModule started
[2025-11-30 16:40:39.980][1][modelmanager][info][modelmanager.cpp:156] Available devices for Open VINO: CPU
[2025-11-30 16:40:39.981][1][serving][info][capimodule.cpp:40] C-APIModule starting
[2025-11-30 16:40:39.981][1][serving][info][capimodule.cpp:42] C-APIModule started
[2025-11-30 16:40:39.981][1][serving][info][grpcservermodule.cpp:102] GRPCServerModule starting
[2025-11-30 16:40:39.982][1][serving][info][grpcservermodule.cpp:179] GRPCServerModule started
[2025-11-30 16:40:39.982][1][serving][info][grpcservermodule.cpp:180] Started gRPC server on port 9123
[2025-11-30 16:40:39.982][1][serving][info][servablemanagermodule.cpp:51] ServableManagerModule starting
[2025-11-30 16:40:39.983][1][serving][info][model.cpp:42] Getting model from /opt/model
[2025-11-30 16:40:39.983][1][serving][info][model.cpp:49] Model downloaded to /opt/model
[2025-11-30 16:40:39.983][1][serving][info][model.cpp:149] Will add model: resnet; version: 1 ...
[2025-11-30 16:40:39.983][1][serving][info][modelversionstatus.cpp:109] STATUS CHANGE: Version 1 of model resnet status change. New status: ( "state": "START", "error_code": "OK" )
[2025-11-30 16:40:39.983][1][serving][info][modelinstance.cpp:1058] Loading model: resnet, version: 1, from path: /opt/model/1, with target device: GPU ...
[2025-11-30 16:40:39.983][1][serving][info][modelversionstatus.cpp:109] STATUS CHANGE: Version 1 of model resnet status change. New status: ( "state": "LOADING", "error_code": "OK" )
[2025-11-30 16:40:40.254][1][modelmanager][info][modelinstance.cpp:593] Input name: input_1; mapping_name: input_1; shape: (-1,224,224,3); precision: FP32; layout: N...
[2025-11-30 16:40:40.254][1][modelmanager][info][modelinstance.cpp:656] Output name: activation_49; mapping_name: activation_49; shape: (-1,1001); precision: FP32; layout: N...
[2025-11-30 16:40:40.255][1][modelmanager][error][modelinstance.cpp:842] Cannot compile model into target device; error: Exception from src/inference/src/cpp/core.cpp:109:
Check '!m_device_map.empty()' failed at src/plugins/intel_gpu/src/plugin/plugin.cpp:518:
[GPU] Can't get PERFORMANCE_HINT property as no supported devices found or an error happened during devices query.
[GPU] Please check OpenVINO documentation for GPU drivers setup guide.
; model: resnet; version: 1; device: GPU
[2025-11-30 16:40:40.255][1][serving][info][modelversionstatus.cpp:109] STATUS CHANGE: Version 1 of model resnet status change. New status: ( "state": "LOADING", "error_code": "UNKNOWN" )
[2025-11-30 16:40:40.255][1][serving][error][model.cpp:154] Error occurred while loading model: resnet; version: 1; error: Cannot compile model into target device
[2025-11-30 16:40:40.255][1][modelmanager][error][modelmanager.cpp:1483] Error occurred while loading model: resnet versions; error: Cannot compile model into target device
[2025-11-30 16:40:40.255][1][serving][info][model.cpp:197] Will clean up model: resnet; version: 1 ...
[2025-11-30 16:40:40.255][1][serving][info][model.cpp:89] Updating default version for model: resnet, from: 0
[2025-11-30 16:40:40.255][1][serving][info][model.cpp:101] Model: resnet will not have default version since no version is available.
[2025-11-30 16:40:40.275][1][modelmanager][error][modelmanager.cpp:184] Couldn't start model manager
[2025-11-30 16:40:40.275][1][serving][error][servablemanagermodule.cpp:58] ovms::ModelManager::Start() Error: Cannot compile model into target device
[2025-11-30 16:40:40.275][1][serving][info][grpcservermodule.cpp:188] GRPCServerModule shutting down
[2025-11-30 16:40:40.275][1][serving][info][grpcservermodule.cpp:193] Shutdown gRPC server
[2025-11-30 16:40:40.275][1][serving][info][grpcservermodule.cpp:198] GRPCServerModule shutdown
[2025-11-30 16:40:40.275][1][serving][info][servablemanagermodule.cpp:65] ServableManagerModule shutting down
[2025-11-30 16:40:40.275][1][serving][info][modelversionstatus.cpp:109] STATUS CHANGE: Version 1 of model resnet status change. New status: ( "state": "UNLOADING", "error_code": "OK" )
[2025-11-30 16:40:40.276][1][serving][info][modelversionstatus.cpp:109] STATUS CHANGE: Version 1 of model resnet status change. New status: ( "state": "END", "error_code": "OK" )
[2025-11-30 16:40:40.276][1][serving][info][servablemanagermodule.cpp:71] ServableManagerModule shutdown
[2025-11-30 16:40:40.276][1][serving][info][pythoninterpretermodule.cpp:61] PythonInterpreterModule shutting down
[2025-11-30 16:40:40.276][1][serving][info][pythoninterpretermodule.cpp:65] PythonInterpreterModule shutdown
[2025-11-30 16:40:40.280][1][serving][info][capimodule.cpp:50] C-APIModule shutting down
[2025-11-30 16:40:40.280][1][serving][info][capimodule.cpp:52] C-APIModule shutdown
The ARC A380 does work for video transcoding, so it can be used from docker.
The system hardware is a Supermicro H13SSL-N with an AMD Epyc Genoa 9334, 384GB RAM, Sparkle Intel Arc A380 ELF 6GB GDDR6 Single Fan SA380E-6G GPU.
OS is Proxmox 8.4, kernel 6.8.12-16-pve, Docker version 29.0.3, build 511dad6, docker is installed directly on the host (no LXC, no VM).
GPU drivers installed are intel-opencl-icd and intel-gpu-tools.
$ uname -r
6.8.12-16-pve
$ lspci -nn | grep -Ei "3d|display|vga"
43:00.0 VGA compatible controller [0300]: Intel Corporation DG2 [Arc A380] [8086:56a5] (rev 05)
c6:00.0 VGA compatible controller [0300]: ASPEED Technology, Inc. ASPEED Graphics Family [1a03:2000] (rev 52)
$ ls -l /dev/dri
total 0
drwxr-xr-x 2 root root        100 Nov  2 07:38 by-path
crw-rw---- 1 root video  226,   0 Nov  2 07:38 card0
crw-rw---- 1 root video  226,   1 Nov  2 07:38 card1
crw-rw---- 1 root render 226, 128 Nov  2 07:38 renderD128
$ sudo intel_gpu_top
intel-gpu-top: Intel Dg2 (Gen12) @ /dev/dri/card1
Please help me troubleshoot why the GPU is not detected?
PieterV
Also working for Immich with the new kernel, so my kernel was too old.
Zulkifli_Intel
Hi PieterV,
Can you run these commands and share the output
lspci -nnk -s 43:00.0
lsmod | grep xe
clinfo | grep Device
Zul
PieterV
Info as requested:
pieter@server-2:~$ sudo lspci -nnk -s 43:00.0
[sudo] password for pieter:
        Subsystem: Device [172f:3943]
        Kernel driver in use: i915
        Kernel modules: i915, xe
pieter@server-2:~$ sudo lsmod | grep xe
xe                   3567616  0
intel_vsec             24576  1 xe
gpu_sched              65536  1 xe
drm_gpuvm              49152  1 xe
drm_gpusvm_helper      36864  1 xe
drm_ttm_helper         16384  1 xe
drm_exec               12288  2 drm_gpuvm,xe
drm_suballoc_helper    16384  1 xe
drm_buddy              28672  2 xe,i915
ttm                   118784  3 drm_ttm_helper,xe,i915
drm_display_helper    274432  2 xe,i915
cec                    94208  3 drm_display_helper,xe,i915
video                  77824  2 xe,i915
i2c_algo_bit           16384  3 ast,xe,i915
pieter@server-2:~$ sudo clinfo | grep Device
sudo: clinfo: command not found
I also made a discovery; I read some posts claiming that a newer kernel may be required, so I upgraded Proxmox from v8 to v9, and the kernel from 6.8 to 6.17, and now it is working!
pieter@server-2:~$ docker run --rm -it  --device=/dev/dri --group-add=$(stat -c "%g" /dev/dri/render* | head -n 1) -u $(id -u):$(id -g) -v ${PWD}/model:/opt/model -p 9123:9123 openvino/model_server:latest-gpu --model_path /opt/model --model_name resnet --port 9123 --target_device GPU
[2025-12-01 19:55:19.292][1][serving][info][server.cpp:88] OpenVINO Model Server 2025.4.0.8db21b815
[2025-12-01 19:55:19.292][1][serving][info][server.cpp:89] OpenVINO backend 2025.4.0.0rc3
[2025-12-01 19:55:19.292][1][serving][info][pythoninterpretermodule.cpp:37] PythonInterpreterModule starting
Python version:
3.12.3 (main, Nov  6 2025, 13:44:16) [GCC 13.3.0]
[2025-12-01 19:55:19.362][1][serving][info][pythoninterpretermodule.cpp:50] PythonInterpreterModule started
[2025-12-01 19:55:19.617][1][modelmanager][info][modelmanager.cpp:156] Available devices for Open VINO: CPU, GPU
[2025-12-01 19:55:19.618][1][serving][info][capimodule.cpp:40] C-APIModule starting
[2025-12-01 19:55:19.618][1][serving][info][capimodule.cpp:42] C-APIModule started
[2025-12-01 19:55:19.618][1][serving][info][grpcservermodule.cpp:110] GRPCServerModule starting
[2025-12-01 19:55:19.618][1][serving][info][grpcservermodule.cpp:137] Binding gRPC server to address: 0.0.0.0:9123
[2025-12-01 19:55:19.620][1][serving][info][grpcservermodule.cpp:192] GRPCServerModule started
[2025-12-01 19:55:19.620][1][serving][info][grpcservermodule.cpp:193] Started gRPC server on port 9123
[2025-12-01 19:55:19.620][1][serving][info][servablemanagermodule.cpp:51] ServableManagerModule starting
[2025-12-01 19:55:19.620][1][serving][info][model.cpp:42] Getting model from /opt/model
[2025-12-01 19:55:19.620][1][serving][info][model.cpp:49] Model downloaded to /opt/model
[2025-12-01 19:55:19.620][1][serving][info][model.cpp:149] Will add model: resnet; version: 1 ...
[2025-12-01 19:55:19.620][1][serving][info][modelversionstatus.cpp:109] STATUS CHANGE: Version 1 of model resnet status change. New status: ( "state": "START", "error_code": "OK" )
[2025-12-01 19:55:19.620][1][serving][info][modelinstance.cpp:1058] Loading model: resnet, version: 1, from path: /opt/model/1, with target device: GPU ...
[2025-12-01 19:55:19.620][1][serving][info][modelversionstatus.cpp:109] STATUS CHANGE: Version 1 of model resnet status change. New status: ( "state": "LOADING", "error_code": "OK" )
[2025-12-01 19:55:20.170][1][modelmanager][info][modelinstance.cpp:593] Input name: input_1; mapping_name: input_1; shape: (-1,224,224,3); precision: FP32; layout: N...
[2025-12-01 19:55:20.170][1][modelmanager][info][modelinstance.cpp:656] Output name: activation_49; mapping_name: activation_49; shape: (-1,1001); precision: FP32; layout: N...
[2025-12-01 19:55:21.387][1][modelmanager][info][modelinstance.cpp:1363] Number of OpenVINO streams: 1
[2025-12-01 19:55:21.387][1][modelmanager][info][modelinstance.cpp:863] Plugin config for device: GPU
[2025-12-01 19:55:21.387][1][modelmanager][info][modelinstance.cpp:867] OVMS set plugin settings key: PERFORMANCE_HINT; value: LATENCY;
[2025-12-01 19:55:21.387][1][serving][info][modelinstance.cpp:930] Loaded model resnet; version: 1; batch size: -1; No of InferRequests: 1
[2025-12-01 19:55:21.387][1][serving][info][modelversionstatus.cpp:109] STATUS CHANGE: Version 1 of model resnet status change. New status: ( "state": "AVAILABLE", "error_code": "OK" )
[2025-12-01 19:55:21.387][1][serving][info][model.cpp:89] Updating default version for model: resnet, from: 0
[2025-12-01 19:55:21.387][1][serving][info][model.cpp:99] Updated default version for model: resnet, to: 1
[2025-12-01 19:55:21.387][187][modelmanager][info][modelmanager.cpp:1200] Started model manager thread
[2025-12-01 19:55:21.387][1][serving][info][servablemanagermodule.cpp:55] ServableManagerModule started
[2025-12-01 19:55:21.387][188][modelmanager][info][modelmanager.cpp:1219] Started cleaner thread
Is there a minimum kernel that is required?
PieterV
PieterV
Or if not the kernel version, it could be that the OpenVino version in the test changed from "2025.3.0.dev20250826" to "2025.4.0.0rc3" between now and a day ago?
Zulkifli_Intel
Hi PieterV,
Thank you for confirming your issue has been resolved and for sharing the resolution with us. The previous configuration (Proxmox 8 and Kernel 6.8) does not work could be due to the Intel GPU driver (xe) being incomplete or unstable. Proxmox 9 and Kernel 6.17 have major fixes and include significant updates to Intel's open-source graphics drivers, including the xe driver.
Zul
Zulkifli_Intel
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
