6594 Discussions
[Bug Report] Exception: Graph Contains a Cycle
Mark_A_Intel
While running mo.py script with a tensorflow protobuf file, the following error occurred, with suggestion to forward to MO devs.
[ ERROR ]  -------------------------------------------------
[ ERROR ]  ----------------- INTERNAL ERROR ----------------
[ ERROR ]  Unexpected exception happened.
[ ERROR ]  Please contact Model Optimizer developers and forward the following information:
[ ERROR ]  Graph contains a cycle.
[ ERROR ]  Traceback (most recent call last):
  File "/opt/intel/computer_vision_sdk_2018.0.234/deployment_tools/model_optimizer/mo/main.py", line 222, in main
    return driver(argv)
  File "/opt/intel/computer_vision_sdk_2018.0.234/deployment_tools/model_optimizer/mo/main.py", line 190, in driver
    mean_scale_values=mean_scale)
  File "/opt/intel/computer_vision_sdk_2018.0.234/deployment_tools/model_optimizer/mo/pipeline/tf.py", line 143, in tf2nx
    partial_infer(graph)
  File "/opt/intel/computer_vision_sdk_2018.0.234/deployment_tools/model_optimizer/mo/middle/passes/infer.py", line 55, in partial_infer
    nodes = nx.topological_sort(graph)
  File "/opt/intel/computer_vision_sdk_2018.0.234/deployment_tools/model_optimizer/venv/lib/python3.5/site-packages/networkx/algorithms/dag.py", line 157, in topological_sort
    raise nx.NetworkXUnfeasible("Graph contains a cycle.")
networkx.exception.NetworkXUnfeasible: Graph contains a cycle.
[ ERROR ]  ---------------- END OF BUG REPORT --------------
Model Optimizer arguments
    Batch:     1
    Precision of IR:     FP32
    Enable fusing:     True
    Enable gfusing:     True
    Names of input layers:     inherited from the model
    Path to the Input Model:     matroid.pb
    Input shapes:     inherited from the model
    Log level:     ERROR
    Mean values:     ()
    IR output name:     inherited from the model
    Names of output layers:     inherited from the model
    Path for generated IR:     /opt/intel/computer_vision_sdk_2018.0.234/deployment_tools/model_optimizer
    Reverse input channels:     False
    Scale factor:     None
    Scale values:     ()
    Version:     0.3.61.37271eb9
    Input model in text protobuf format:     False
    Offload unsupported operations:     False
    Path to model dump for TensorBoard:     None
    Update the configuration file with input/output node names:     None
    Operations to offload:     None
    Patterns to offload:     None
    Use the config file:     None
I'm not able to find anything in the documentation about how to handle cycles within the graph, but imagine it may require offloading into TensorFlow.  Any information regarding this would be extremely helpful.  Thanks!
Shubha_R_Intel
Done. I have forwarded this to the Model Optimizer Devs.  Thank You Mark.
Shubha
Shubha_R_Intel
Mark I have contacted Intel Developers and they would like you to share a freezed model. Can you kindly attach that ?
Shubha
Mark_A_Intel
This model is actually proprietary from one of our ISVs, and I would not want to send it to a public forum.  Is there an email address I could forward a copy of this model to to have it looked at?  Thanks.
Mark
chen__ives
In few days ago, I tried to convert TensorFlow models: SSD MobileNet and SSD InceptionV2 via MO, but encountered similar issue. Then I followed direction in "C:/Intel/computer_vision_sdk_2018.1.249/deployment_tools/documentation/docs/TensorFlowObjectDetectionSSD.html", and this issue is resolved.
Take SSD MobileNet for example, you may need use mo_tf.py to covert it, like
python mo_tf.py --input_model "C:\Intel\computer_vision_sdk_2018.1.249\deployment_tools\ssd_mobilenet_v1_coco_2017_11_17\frozen_inference_graph.pb" --input=1:Preprocessor/mul --input_shape="(1,300,300,3)" --tensorflow_use_custom_operations_config extensions/front/tf/ssd_support.json --output="detection_boxes,detection_scores,num_detections" --output_dir "C:\Intel\computer_vision_sdk_2018.1.249\deployment_tools\intel_models\ssd_mobilenet_v1_coco_2017_11_17"
I'm still not familiar with this Python module, and above just a trail-and-error result.
Hope it would be helpful.
Sergey_L_Intel2
Based on symptoms, this is a graph with control flow that may or may not be an essential part of the model. Cycles in graphs are supported for predefined number of models – SSDs built with TF Detection API – where they are just eliminated. In general case cycles are not supported. Common recipe: the graph should be analyzed (for example in TensorBoard) to identify straightforward convolutional parts that consist of supported TF operations without cycles. These parts should be converted to IR. All other parts should be done as pre-/post-processing outside IE IR.
mohan__deepa
Hi Sergey
Could you please explain this a little more?
1. Why is the control flow cyclic graph not an essential part of the model?
2. Could you please give an example of where the SSD graph could have a cycle and how eliminating it is ok from an IR perspective?
3.  Is it very hard to visualize graph cycles in tensorboard so if you can throw some light on where in the seq2seq model, there could be a potential graph cycle, that will help a lot
Deepa
Herings__Kai
Hi There,
I am stuck at the same issue. I did train an SSD InceptionV2 with tensorflow, afterwards freezing up the net, now having my frozen.pb net.
I want it to be optimized for the AWS deeplens - basically the wrapper around the intel model optimizer is a little sub-optimal, so you do end up with searching a lot for the actual error.
[ERROR]-mo.py:160,[ WARNING ]
Detected not satisfied dependencies:
numpy: installed: 1.14.5, required: 1.13.0
Please install required versions of components or use install_prerequisites script
/opt/awscam/intel/deeplearning_deploymenttoolkit/deployment_tools/model_optimizer/install_prerequisites/install_prerequisites_tf.sh
Note that install_prerequisites scripts may install additional components.
File "/opt/awscam/intel/deeplearning_deploymenttoolkit/deployment_tools/model_optimizer/mo/main.py", line 222, in main
return driver(argv)
File "/opt/awscam/intel/deeplearning_deploymenttoolkit/deployment_tools/model_optimizer/mo/main.py", line 190, in driver
File "/opt/awscam/intel/deeplearning_deploymenttoolkit/deployment_tools/model_optimizer/mo/pipeline/tf.py", line 143, in tf2nx
File "/opt/awscam/intel/deeplearning_deploymenttoolkit/deployment_tools/model_optimizer/mo/middle/passes/infer.py", line 55, in partial_infer
File "/usr/local/lib/python3.5/dist-packages/networkx/algorithms/dag.py", line 157, in topological_sort
The model optimizer is called through the mo wrapper method - https://docs.aws.amazon.com/deeplens/latest/dg/deeplens-model-optimizer-api-functions_and_objects.html
I would optimize the model manually, but the solution above ...
 ...does not translate to my problem
Applying the call (without input shape) leads to "Sub-graph contains network input node "image_tensor". For more ... FAQ75
Specifying the input shape of (1,224,224,3) leads to "Other inputs needed for output computation" 27
In the first place I would like to get rid of the circle without bumping in substituion problems.
Any ideas?
Herings__Kai
I finally solved the problem, which was occuring on AWS Deeplens with the deployed version of the model optimizer (awscam.mo). It occured due to the fact that an old Intel Open Vino version was deployed & the underlying net didn't have the right version. I documented the solution in my blog article that I was writing ...
https://blog.codecentric.de/2018/07/deep-learning-diesel-aws-deeplens/
It's in German, an English version will follow later. Regards, Kai
Zicheng_R_Intel
I ran into the same issue here when running mo_tf.py on my frozen.pb. I am suspecting that the cycle issue is rooted in tf.while_loop(). Do you know if MO is able to handle dynamic RNN layers?
Thanks!
Monique_J_Intel
Hi Richard,
Currently MO doesn't support dynamic RNN layers or RNN networks but I will create a feature request for this.
Kind Regards,
Monique Jones
Herings__Kai
I have updated the description how I finally managed to work around the issue. Hope this helps: https://blog.codecentric.de/en/2018/11/aws-deep-lens-diesel-car-detection/
K__Mike
In case I wish to fix the graph using the Point 97 in the Mo_FAQ.html document in the VINO documentation docs,
which nodes do I include in  the first command -
python3 mo.py --input_model model/frozen_inference_graph.pb --tensorflow_subgraph_pattern ""FeatureExtractor/MobilenetV1/MobilenetV1/Conv2d_0/BatchNorm/FusedBatchNorm, FeatureExtractor/MobilenetV1/MobilenetV1/Conv2d_0/Relu6, FeatureExtractor/MobilenetV1/MobilenetV1/Conv2d_1_depthwise/depthwise, FeatureExtractor/MobilenetV1/MobilenetV1/Conv2d_1_depthwise/BatchNorm/FusedBatchNorm, FeatureExtractor/MobilenetV1/MobilenetV1/Conv2d_1_depthwise/Relu6,..
Which of the nodes do I put above to offload a sub-graph of operations?
(Actual .pbtxt file had about 100 nodes)
Matsak__Art
Monique, can you please confirm that MO still doesn't support RNNs? We're getting "Graph contains a cycle" when trying to optimize a GRU network.
Shubha_R_Intel
Dear Matsak, Art,
OpenVino does support several RNN-like layers such as GRU, LSTM, and RNN sequence layers.
If you peruse the  Release Notes and do a search on RNN you will find out exactly what OpenVino supports.
May I know more about the model you're using ?
Shubha
Matsak__Art
Dear Shubha, thank you. We're using a bi-directional GRU recurrent network. The model is trained with Keras/TensorFlow and we're trying to convert it with mo_tf.py. However, we're running into the "Graph contains a cycle" error. Hence my question regarding mo_tf.py (not OpenVINO itself) not supporting RNN conversion yet. Please let me know.
Matsak__Art
Dear Shubha, thank you for your comments. The problem seems to be not in OpenVINO itself but in the mo_tf.py script. We use it to optimize/convert a TensorFlow bi-directional GRU model, and it fails with the "Graph contains a cycle" error. Hence my question regarding MO (not OpenVINO) not supporting RNNs yet.
