Build Error on LNK2001
WeiSeng
Prerequisite:
- Window10 OS
- Install OpenVINO 2023.0
When we try to setting the openVINO path point to our working directory cause build error:
__declspec(dllimport)  class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char>>cdecl
ov::node_validation_failure_loc_string(class ov::Node const*)" (imp_? node_validation_failure_loc_string@@ov@@YA?AV$basic_string@DU?
$char_traits@D@std@@V$allocator@D@2@@std@@PEBVNODE@1@@Z)
I also attached the error message picture.
Please point me where to configure in order solve this issue?
Iffa_Intel
could you share:
  1. which hardware you are using (eg: laptop with i7 CPU + UHD GPU, Intel SGX, etc) ?
  2. which OpenVINO guides are you following: Runtime on Windows or Build from source ?
  3. which version of Visual Studio are you using?
  4. Steps you've done up till point of error (with commands that you used if possible)
Cordially,
Iffa
WeiSeng
Thanks for supporting us, Iffa!
Here my reply:
  1. which hardware you are using (eg: laptop with i7 CPU + UHD GPU, Intel SGX, etc) ?   [Using laptop with i7+UHD GPU, and Window10 OS]
    1. which OpenVINO guides are you following: Runtime on Windows?  [Yes, we're follow the guide to install is working fine. And we move our working directory to new working directory, because we need to integrate with our application. This directory setting: 'C:\solution'
  2. which version of Visual Studio are you using? [visual studio 2019 (16.11.6)]
  3. Steps you've done up till point of error (with commands that you used if possible)
My question is by default openVINO C++ working directory is this 'C:\Program Files (x86)\Intel\openvino_2023'
If we need to move this default directory to this 'C:\solution', what need to be taken care (like environment configuration setting) and what openVINO library folders need to move over in order to building successfully?
Thanks again!
Iffa_Intel
Generally,
there are two CMakelist.txt involved when compiling OpenVINO C++ in Windows Runtime(I created a new dir named test):
  1. OVpath\samples\cpp\CMakeLists.txt
  2. OVpath\samples\cpp\object_detection_sample_ssd\CMakeLists.txt
I'll leave CMAkeList file at number 1 as it is and edit number 2.
Then, I built it
The binary is generated without error.
Cordially,
Iffa
WeiSeng
Hi Iffa,
Thanks for information.
your working environment still in default : C:\Program Files (x86)\Intel\openvino_2023 ??
If our working environment is not in this openVINO default folder directory, mean we put into 'c:\solution', openVINO all the folder need move to our working directory?
Or we install openVINO on default directory (mean this C:\Program Files (x86)\Intel\openvino_2023), and just update CMakeList.txt?
Thanks for support!
Or I can setup a call with you? can you provide me your Intel email?
WS Yeap
Iffa_Intel
Same concept applies if you change your dir.
Required files/folder: common, thirdparty, build_samples_msvc.bat,CMakeLists.txt
I created test2 folder with the same content as I've shown before with its CMakelist
Init setupvars beforehand & compile:
Success Compilation:
Binary produced:
Cordially,
Iffa
WeiSeng
Thanks Iffa,
We managed to solve the linking issue.
Now when we load the dll seem is fail.
I attached the picture for you, you can advise us?
Thanks!
Iffa_Intel
To answer that, I need more information:
  1. what is your use case? (eg: used inferencing code from OpenVINO sample with YOLO model)
  2. did you make changes to the original OpenVINO setup (files/codes/etc other than the one I showed previously)
Please note that it is best to use the original OpenVINO setup files as it is instead of creating custom ones.
Cordially,
Iffa
WeiSeng
Hi Iffa,
  1. what is your use case? (eg: used inferencing code from OpenVINO sample with YOLO model) The use-cases is for object detection and using YOLO model.
  2. did you make changes to the original OpenVINO setup (files/codes/etc other than the one I showed previously) We updated the CMakeList file, is there any file need to setting to solve the dll loading fail?
Thanks!
Iffa_Intel
I hope you noticed that there are 2 CMakeList files.
Please use the original CMakeList without changes in the main folder, mine is in C:\Users\sjaismex\OV_test
The only changeable CMakeList is in your custom (newly created folder), mine is in C:\Users\sjaismex\OV_test\test2:
Run the setupvars.bat before doing any compilation/build or inferencing.
If you've done this properly as mentioned and your custom inferencing code has no problem, there shouldn't be issue with the setup files/linker.
Cordially,
Iffa
WeiSeng
Thanks Iffa,
One question on the *.dll loading fail still happen.
This is the Cmake file that original:
And the directory that we change the Cmake file:
1. Build is success
2. When run DEBUG, the DLL load fail like below :
Failed(code:126) to load C:\app\10_siav2_git\18_siav2_edge\bin\x64\Release\jobmodules\Jobmodule_detector_yolo_openvino.dll
Any suggestions?
Thanks!
Iffa_Intel
Edit your build_samples_msvc.bat.
Change
echo "!MSBUILD_BIN!" Samples.sln /p:Configuration=Release
To
echo "!MSBUILD_BIN!" Samples.sln /p:Configuration=Debug
Then build again as previously done.
You should have Debug folder with its binaries.
Run your dbg with the Debug binary and see whether the issue persist.
Note: don't forget to run setupvars.bat beforehand
Cordially,
Iffa
WeiSeng
Thanks Iffa,
Are we have the guide (in DOC/PDF) on how to configure new project for openVINO for C++ on Windows OS?
Thanks!
Iffa_Intel
Iffa_Intel
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
