Caffe GoogleNet Make Profile Error
Hello everyone,
I already installed the NCSDK 2.0 and I was able to run the basic hello_ncs_cpp app, which makes me think everything was properly installed. However, when I try to test the Caffe GoogleNet examples and ran into issues. I identified the problem is when running the make profile command, below is the output I get. Specifically it is related to the _mvNCProfile deploy.prototxt -s 12_ command.
Could you please help me pointing out to what could be wrong with my setup?
Thanks for your help in advance.
  • Carlos R.
Make profile Output:
\nmaking prereqs (cd ../../data/ilsvrc12; make) make[1]: Entering directory /home/crodriguez/work/intel_movidius/workspace_2.0/ncsdk-2.05.00.02/examples/data/ilsvrc12 make[1]: Leaving directory /home/crodriguez/work/intel_movidius/workspace_2.0/ncsdk-2.05.00.02/examples/data/ilsvrc12 \nmaking prototxt Prototxt file already exists \nmaking profile mvNCProfile deploy.prototxt -s 12 mvNCProfile v02.00, Copyright @ Intel Corporation 2017 ****** WARNING: using empty weights ****** Layer inception_3b/1x1 forced to im2col_v2, because its output is used in concat /usr/local/bin/ncsdk/Controllers/FileIO.py:65: UserWarning: You are using a large type. Consider reducing your data sizes for best performance Blob generated [Error 7] Toolkit Error: USB Failure. Code: No devices found *** Error in python3: double free or corruption (out): 0x00000000016a05b0 *** ======= Backtrace: ========= /lib/x86_64-linux-gnu/libc.so.6(+0x777e5)[0x7f9ff27377e5] /lib/x86_64-linux-gnu/libc.so.6(+0x8037a)[0x7f9ff274037a] /lib/x86_64-linux-gnu/libc.so.6(cfree+0x4c)[0x7f9ff274453c] /usr/lib/x86_64-linux-gnu/libprotobuf.so.9(_ZN6google8protobuf8internal28DestroyDefaultRepeatedFieldsEv+0x1f)[0x7f9fbd80b8af] /usr/lib/x86_64-linux-gnu/libprotobuf.so.9(_ZN6google8protobuf23ShutdownProtobufLibraryEv+0x8b)[0x7f9fbd80ab3b] /usr/lib/x86_64-linux-gnu/libmirprotobuf.so.3(+0x233b9)[0x7f9fa80ce3b9] /lib64/ld-linux-x86-64.so.2(+0x10de7)[0x7f9ff2cb7de7] /lib/x86_64-linux-gnu/libc.so.6(+0x39ff8)[0x7f9ff26f9ff8] /lib/x86_64-linux-gnu/libc.so.6(+0x3a045)[0x7f9ff26fa045] python3[0x60db0f] python3[0x60dbfa] python3(PyErr_PrintEx+0x36)[0x60dc66] python3(PyRun_SimpleFileExFlags+0x1d9)[0x60ef29] python3(Py_Main+0x456)[0x63fb26] python3(main+0xe1)[0x4cfeb1] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f9ff26e0830] python3(_start+0x29)[0x5d6049] ======= Memory map: ======== 00400000-007a9000 r-xp 00000000 08:02 20448477 /usr/bin/python3.5 009a9000-009ab000 r--p 003a9000 08:02 20448477 /usr/bin/python3.5 009ab000-00a42000 rw-p 003ab000 08:02 20448477 /usr/bin/python3.5 00a42000-00a73000 rw-p 00000000 00:00 0 01600000-09f39000 rw-p 00000000 00:00 0 [heap] 7f9f88000000-7f9f88021000 rw-p 00000000 00:00 0 7f9f88021000-7f9f8c000000 ---p 00000000 00:00 0 7f9f8cd50000-7f9f8cd90000 rw-p 00000000 00:00 0 7f9f8d608000-7f9f8d648000 rw-p 00000000 00:00 0 7f9f8d788000-7f9f8d8c8000 rw-p 00000000 00:00 0 7f9f8d908000-7f9f8d948000 rw-p 00000000 00:00 0 7f9f8d988000-7f9f8da88000 rw-p 00000000 00:00 0 7f9f8dac8000-7f9f8db88000 rw-p 00000000 00:00 0 7f9f8dbc8000-7f9f8dc88000 rw-p 00000000 00:00 0 7f9f8ddc8000-7f9f8de48000 rw-p 00000000 00:00 0 7f9f8dec8000-7f9f8dee5000 r-xp 00000000 08:02 20456499 /usr/lib/x86_64-linux-gnu/libyaml-0.so.2.0.4 7f9f8dee5000-7f9f8e0e5000 ---p 0001d000 08:02 20456499 /usr/lib/x86_64-linux-gnu/libyaml-0.so.2.0.4 7f9f8e0e5000-7f9f8e0e6000 r--p 0001d000 08:02 20456499 /usr/lib/x86_64-linux-gnu/libyaml-0.so.2.0.4 . . [VERY LONG BACKTRACE HERE] . 7f9f985f4000-7f9f987f3000 ---p 00006000 08:02 20457251 /usr/lib/libcdt.so.5.0.0 7f9f987f3000-7f9f987f4000 r--p 00005000 08:02 20457251 /usr/lib/libcdt.so.5.0.0 7f9f987f4000-7f9f987f5000 rw-p 00006000 08:02 20457251 /usr/lib/libcdt.so.5.0.0 7f9f987f5000-7f9f98809000 r-xp 00000000 08:02 20457253 /usr/lib/libcgraph.so.6.0.0Makefile:65: recipe for target 'profile' failed make: *** [profile] Aborted (core dumped)
@CarlosR Hi. It seems like your USB is disconnecting from the system. Are you using a VM? There is a known issue with the current NCSDK and VMs where the NCS device keeps disconnecting.
Hi @Tome_at_Intel. Above log was with the NCS disconnected, I thought it was not necessary for the make profile. Below is with the NCS connected, the same issue appears:
\nmaking prereqs (cd ../../data/ilsvrc12; make) make[1]: Entering directory '/home/crodriguez/work/intel_movidius/workspace_2.0/ncsdk-2.05.00.02/examples/data/ilsvrc12' make[1]: Leaving directory '/home/crodriguez/work/intel_movidius/workspace_2.0/ncsdk-2.05.00.02/examples/data/ilsvrc12' \nmaking prototxt Prototxt file already exists \nmaking profile mvNCProfile deploy.prototxt -s 12 mvNCProfile v02.00, Copyright @ Intel Corporation 2017 ****** WARNING: using empty weights ****** Layer inception_3b/1x1 forced to im2col_v2, because its output is used in concat /usr/local/bin/ncsdk/Controllers/FileIO.py:65: UserWarning: You are using a large type. Consider reducing your data sizes for best performance Blob generated USB: Transferring Data... Time to Execute : 114.92 ms USB: Myriad Execution Finished Time to Execute : 96.98 ms USB: Myriad Execution Finished USB: Myriad Connection Closing. USB: Myriad Connection Closed. Network Summary Detailed Per Layer Profile . . . Generating Profile Report 'output_report.html'... *** Error in python3': double free or corruption (out): 0x0000000002e45f90 *** ======= Backtrace: ========= /lib/x86_64-linux-gnu/libc.so.6(+0x777e5)[0x7ff1815017e5] /lib/x86_64-linux-gnu/libc.so.6(+0x8037a)[0x7ff18150a37a] /lib/x86_64-linux-gnu/libc.so.6(cfree+0x4c)[0x7ff18150e53c] /usr/lib/x86_64-linux-gnu/libprotobuf.so.9(_ZN6google8protobuf8internal28DestroyDefaultRepeatedFieldsEv+0x1f)[0x7ff14c5d58af] /usr/lib/x86_64-linux-gnu/libprotobuf.so.9(_ZN6google8protobuf23ShutdownProtobufLibraryEv+0x8b)[0x7ff14c5d4b3b] /usr/lib/x86_64-linux-gnu/libmirprotobuf.so.3(+0x233b9)[0x7ff136e983b9] /lib64/ld-linux-x86-64.so.2(+0x10de7)[0x7ff181a81de7] /lib/x86_64-linux-gnu/libc.so.6(+0x39ff8)[0x7ff1814c3ff8] /lib/x86_64-linux-gnu/libc.so.6(+0x3a045)[0x7ff1814c4045] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf7)[0x7ff1814aa837] python3(_start+0x29)[0x5d6049] ======= Memory map: ======== 00400000-007a9000 r-xp 00000000 08:02 20448477 /usr/bin/python3.5 009a9000-009ab000 r--p 003a9000 08:02 20448477 /usr/bin/python3.5 009ab000-00a42000 rw-p 003ab000 08:02 20448477 /usr/bin/python3.5 00a42000-00a73000 rw-p 00000000 00:00 0 02946000-0b272000 rw-p 00000000 00:00 0 [heap] 7ff10c000000-7ff10c021000 rw-p 00000000 00:00 0 . . [VERY LONG BACKTRACE HERE] . 7ff128190000-7ff12838f000 ---p 0002a000 08:02 25975624 /usr/local/lib/python3.5/dist-packages/skimage/transform/_seam_carving.cpython-35m-x86_64-linux-gnu.so 7ff12838f000-7ff128392000 rw-p 00029000 08:02 25975624 /usr/local/lib/python3.5/dist-packages/skimage/transform/_seam_carving.cpython-35m-x86_64-linux-gnu.soMakefile:65: recipe for target 'profile' failed make: *** [profile] Aborted (core dumped)
