Can I debug when using mvNCcompile?
I am trying to compile (converting to myriad graph) my own caffemodel.
But while using 'mvNCCompile', I got following error.
input: "data" input_shape{ dim: 1 dim: 3 dim: 224 dim: 224 } layer{ name: "conv1/7x7_s2" type: "Convolution" bottom: "data" top: "conv1/7x7_s2" ...
mvNCCompile v02.00, Copyright @ Movidius Ltd 2016 Error importing caffe
I want to know why I failed. Is there a way to debug it?
@hra.kim Can you double check your PYTHONPATH variable inside of bashrc? Inside of the ~/.bashrc file, there should be a line export PYTHONPATH="${PYTHONPATH}:/opt/movidius/caffe/python". In the folder /opt/movidius, there should be a softlink named caffe. This points to whichever version of caffe is being used with the NCSDK. Please make sure this softlink is there and it is pointing to a valid version of caffe.
Resolved. It's kinds of PYTHONPATH problem as you noticed.
