Can I use my own ssd model with NCSDK ?
hi, I used my own ssd model using codes from apps/video_object, but executed failed. I changed class number with my class number, mask, etc. Its execution result is as below:
python video_objects.py actual video resolution: 320.0 x 240.0 [ nan nan nan ..., nan nan nan] Traceback (most recent call last): File "video_objects.py", line 414, in <module> sys.exit(main()) File "video_objects.py", line 377, in main run_inference(display_image, ssd_mobilenet_graph) File "video_objects.py", line 238, in run_inference num_valid_boxes = int(output[0]) ValueError: cannot convert float NaN to integer
Thanks in advance. :smile:
What modifications should I do if using my own ssd model? :wink:
I also get all Nan result when port my similar ssd detect net. as my last two lay like:
layer {
type: "Concat"
bottom: "Concat_Locpreds"
bottom: "Concat_Confpreds"
top: "Concat_LocConfpreds"
concat_param {
axis: 2
layer {
type: "Reshape"
bottom: "Concat_LocConfpreds"
top: "last_layer_reshape"
reshape_param {
shape {
dim: 0
dim: 0
dim: 0
