Can not init Myriad device: NC_ERROR
Zhu__Dongzhi
Intel i5-7300CPU
GPU intel HD Graphics 620
VMware Ubuntu 16.04.6 LTS
openVINO R2   with NCS2
error code:
~/inference_engine_samples_build/intel64/Release$ ./classification_sample_async -i /opt/intel/openvino/deployment_tools/demo/car.png -m ~/openvino_models/ir/FP16/classification/squeezenet/1.1/caffe/squeezenet1.1.xml -d MYRIAD
[ INFO ] InferenceEngine:
    API version ............ 2.0
    Build .................. custom_releases/2019/R2_f5827d4773ebbe727c9acac5f007f7d94dd4be4e
    Description ....... API
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     /opt/intel/openvino/deployment_tools/demo/car.png
[ INFO ] Creating Inference Engine
    MYRIAD
    myriadPlugin version ......... 2.0
    Build ........... 27579
[ INFO ] Loading network files
[ INFO ] Preparing input blobs
[ WARNING ] Image is resized from (787, 259) to (227, 227)
[ INFO ] Batch size is 1
[ INFO ] Loading model to the device
E: [ncAPI] [    645153] [classification_] ncDeviceOpen:844    Failed connection to device (1.1-ma2480) with error 7
[ ERROR ] Can not init Myriad device: NC_ERROR
i  run /install_NCS_udev_rules.sh
install successfully
before i ran the demo, i can list usb
lsusb
Bus 001 Device 010: ID 03e7:2485
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
Bus 002 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
once begin to run the demo, the usb diconnect and lose the serial
what is the problem?
Note that i run the demo successfully with NCS2 in Win10
Michael_C_Intel1
Hello DongzhiZ,
The computer vision forum for OpenVINO is a more appropriate place for discussion on this topic, I will move this thread there. That being said, I'm concerned about support through OS virtualization software... that may or may not be in the scope of a software supported configuration.
-MichaelC
Shubha_R_Intel
Dear Zhu, Dongzhi,
This Virtual Box USB OpenVino Post may help you. It's not VMWare but the symptom may be the same, which is:
It seems NCS2 USB device ID changes when script starts loading model to MYRIAD.
I was able to resolve it by adding a new USB device filter with VID= 03e7 and PID=f63b in addition to VID= 03e7 and PID=2485 in Virtualbox USB settings.
Hope this solves your problem
Hope it helps,
Shubha
Dongzhi_Z_Intel
Shubha R. (Intel) wrote:
Dear Zhu, Dongzhi,
Hope it helps,
Shubha
Dear Shubha:
    I solved my problem by changing USB controller from 2.0 to 3.0 for all my usb filters in my Virtual machine settings .
    Thanks a lot for your suggestion!
Dongzhi
Dongzhi_Z_Intel
MICHAEL C. (Intel) wrote:
Hello DongzhiZ,
-MichaelC
uration.
Hello MichaelC:
 I change USB controller from 2.0 to 3.0 for all my usb filters in my Virtual machine settings  and solved the problem,.
 Thank you for your suggestions.
Dongzhi
Shubha_R_Intel
Dear Dongzhi,
This is a great find and thank you for sharing with the OpenVino community ! It's always great to help each other out.
Shubha
Schwojer__Georg
I get the identical error message on my raspberry pi 4 with Buster :"E: [ncAPI] [    599854] [object_detectio] ncDeviceOpen:859    Device doesn't appear after boot"
Setup:
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
Installed is: OpenVINI 4.1.2 and opencv newest version
LSUSB shows:
pi@raspberrypi:~ $ lsusb
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 007: ID 18a5:0302 Verbatim, Ltd Flash Drive
Bus 001 Device 008: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 011: ID 03e7:2485 Intel Movidius MyriadX
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
I did these setup exactly es desribed in the Intel site: https://software.intel.com/en-us/articles/raspberry-pi-4-and-intel-neural-compute-stick-2-setup and the corespondig site.
Especially the usb rules and user setting are done.
Tests are done with
  • Benchmark app:
    ././benchmark_app  -i /home/pi/Pictures/president_reagan-62x62.png -m ~/models/age-gender-recognition-retail-0013.xml –pp ./lib –api async -d MYRIAD
  • object_detection_sample_ssd
    ./object_detection_sample_ssd  -i /home/pi/Pictures/PNGs-Von-723/frame_0001.jpg -m ~/models/frozen_inference_graph.xml  -d MYRIAD
Output from the last:
(cv) pi@raspberrypi:~/OpenVINO/dldt/inference-engine/bin/armv7l/Release $ ./object_detection_sample_ssd  -i /home/pi/Pictures/PNGs-Von-723/frame_0001.jpg -m ~/models/frozen_inference_graph.xml  -d MYRIAD
    API version ............ 2.1
    Build .................. custom_2019_b0c5accaf8e0c0fac17aaef688478d7f391d05bb
[ INFO ]     /home/pi/Pictures/PNGs-Von-723/frame_0001.jpg
[ INFO ] Loading Inference Engine
[ INFO ] Device info:
    MYRIAD
    myriadPlugin version ......... 2.1
    Build ........... custom_2019_b0c5accaf8e0c0fac17aaef688478d7f391d05bb
[ INFO ] Loading network files:
    /home/pi/models/frozen_inference_graph.xml
    /home/pi/models/frozen_inference_graph.bin
[ INFO ] Preparing output blobs
Thanks in advance for any hints
JesusE_Intel
Hi Georg,
Could you provide the content of the /etc/udev/rules.d/*myriad-usbboot.rules? Also, it looks like you built OpenVINO from source, could you try using the pre-built package?
Please follow these instructions and download the following OpenVINO toolkit for Raspbian OS package.
https://download.01.org/opencv/2019/openvinotoolkit/R3/l_openvino_toolkit_runtime_raspbian_p_2019.3.334.tgz
Jesus
Yuri_Tkachov
I get the same error with INCS2 on Windows 10 without any virtual boxes. To tell the truth, it works properly from time to time. But in some condition it happens and then nothing helps, including driver re-installation, system reboot, NOTHING. And after some valuable amount of time it works again!
Windows 10
OpenVINO 2020.1 (and OpenVINO2019.3 as well)
INCS2
When INCS2 is recognized by system as Movidius MyriadX among Universal Serial Bus devices output of object_detection_demo_ssd_async.exe looks like this:
InferenceEngine: 00007FF8D48CB740
[ INFO ] Reading input
MFX: Can't initialize session
    MYRIAD
    Build ........... 37988
[ INFO ] Batch size is forced to  1.
[ INFO ] Checking that the inputs are as the demo expects
[ INFO ] Checking that the outputs are as the demo expects
<[35mE: [ncAPI] [         0] [] ncDeviceOpen:1012       Failed to find booted device after boot<[0m
While loading model to the device Windows notification appears that said:
The last USB device you connected to this computer malfunctioned, and Windows does not recogize it.
Recommendation: Try reconnecting the device. If Windows still does not recognize it, your device may not be working properly.
After that device is shown in Device Manager as WinUsb Device.
demo output looks like this:
InferenceEngine: 00007FF8D40FB740
    MYRIAD
Benguigui__Michael
Hi, I would need your help, on the same NC_ERROR issue I am facing, when using OpenVINO DL Workbench. I strictly followed the docker install procedure (https://docs.openvinotoolkit.org/latest/_docs_Workbench_DG_Install_from_Docker_Hub.html). Then, from the UI, after having imported the model and the data and selected the Myriad environment, the inference stops at 23% with the following error messge: "Can not init Myriad device: NC_ERROR". But it works using the CPU environment.
Any Idea?
Thanks in advance.
Ileni__Tudor
hi all,
I have the same problem when running the samples on Ubuntu 18.04 (in both VM and non-VM environment).
I worked to run the sample on CPU and GPU, but not with MYRIAD.
I managed to set the USB rules as:
SUBSYSTEM=="usb", ATTRS{idProduct}=="2150", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0660", ENV{ID_MM_DEVICE_IGNORE}="1"
SUBSYSTEM=="usb", ATTRS{idProduct}=="2485", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0660", ENV{ID_MM_DEVICE_IGNORE}="1"
SUBSYSTEM=="usb", ATTRS{idProduct}=="f63b", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0660", ENV{ID_MM_DEVICE_IGNORE}="1"
but the same error occurs:  "Can not init Myriad device: NC_ERROR".
The solution was to set my_user's primary group to the users group.
I use the following command: newgrp users.
Hope will work four you too.
N__Gautham
Hi All,
I have a similar issue with NCS-2 Connectivity, details:
Os- windows 10
model- ResNet-50
I was able to optimize it and got results when running through CPU and NCS-2.
But when NCS-2 is left connected to the system for while without inferencing and try to inference after few minutes it disconnects and throws the error as
"E: [ncAPI] [         0] [] ncDeviceOpen:859     Device doesn't appear after boot"
And it takes a few minutes to reconnect and give the results.
So, Please suggest me some solution.
Spaggiari__Jean-Marc
I'm happy to see that I'm not the only one facing this issue. Interesting to know if anyone solved it.
Benguigui__Michael
HI IIeni, I am running openvino dl workbench UI through a docker container. I tested with the docker run option "--user openvino:users" but I get an error when starting the container ( could not access private key file "/etc/ssl/private/ssl-cert-snakeoil.key": Permission denied ). It seems that setting primary group to users does not give enough access rights.
Ileni, Tudor wrote:
hi all,
Benguigui__Michael
Still encountering the same issue with the lastest workbench UI version 1.0.2859.4692d612.  Still got "Can not init Myriad device: NC_ERROR" using the VPU... but it works well using the CPU (at the inference stage)
Here is the log :
app.error.job_error.CompoundInferenceError: [ ERROR ] Can not init Myriad device: NC_ERROR
[2020-05-20 09:57:03,779: INFO/ForkPoolWorker-5] emitting event "events" to all [/feed]
01bbb6ea77d740fb97eafbaf907737f3: Sending packet MESSAGE data 2/feed,["events",{"code":4002,"message":"[ ERROR ] Can not init Myriad device: NC_ERROR","details":""}]
[2020-05-20 09:57:03,905: INFO/ForkPoolWorker-5] emitting event "inference_model" to all [/inference_model]
01bbb6ea77d740fb97eafbaf907737f3: Sending packet MESSAGE data 2/inference_model,["inference_model",{"creationTimestamp":1589968607.23931,"jobId":6,"type":"SingleInferenceJob","config":{"modelId":2,"datasetId":3,"deviceId":2,"batch":1,"nireq":2,"inferenceTime":20.0,"previousJobId":null},"result":[{"execInfo":{"nireq":2,"batch":1,"latency":null,"throughput":null,"totalExecutionTime":null}}],"projectId":2,"originalModelId":2,"inferenceResultId":2,"status":{"progress":27.0,"name":"error","errorMessage":"[ ERROR ] Can not init Myriad device: NC_ERROR"}}]
[2020-05-20 09:57:04,080: ERROR/ForkPoolWorker-5] Task app.main.tasks.task.Task[45043d69-6e47-49d9-97db-76ffa4157990] raised unexpected: GeneralError('[ ERROR ] Can not init Myriad device: NC_ERROR',)
Traceback (most recent call last):
  File "/usr/local/lib/python3.6/dist-packages/celery/app/trace.py", line 385, in trace_task
    R = retval = fun(*args, **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/celery/app/trace.py", line 648, in __protected_call__
    return self.run(*args, **kwargs)
  File "/opt/intel/openvino_2020.2.120/deployment_tools/tools/workbench/app/main/tasks/task.py", line 54, in run
    self.job.run()
  File "/opt/intel/openvino_2020.2.120/deployment_tools/tools/workbench/app/main/jobs/single_inference/single_inference_job.py", line 77, in run
    self.run_benchmark_app(parameters, parser)
  File "/opt/intel/openvino_2020.2.120/deployment_tools/tools/workbench/app/main/jobs/single_inference/single_inference_job.py", line 115, in run_benchmark_app
    return_code, message = run_console_tool(parameters, parser, self, measure_performance=True)
  File "/opt/intel/openvino_2020.2.120/deployment_tools/tools/workbench/app/main/jobs/tools_runner/runner.py", line 75, in run_console_tool
    parser.parse(output.strip())
  File "/opt/intel/openvino_2020.2.120/deployment_tools/tools/workbench/app/main/console_tool_wrapper/benchmark_app/console_output_parser.py", line 48, in parse
    raise CompoundInferenceError(string, self.emit_message.job_id)
app.error.general_error.GeneralError: [ ERROR ] Can not init Myriad device: NC_ERROR
[2020-05-20 09:57:06,714: DEBUG/MainProcess] heartbeat_tick : for connection 82be60ca2edb4f2798322a23429d2bbb
[2020-05-20 09:57:06,714: DEBUG/MainProcess] heartbeat_tick : Prev sent/recv: 34/616, now - 36/649, monotonic - 162229.495735012, last_heartbeat_sent - 162229.495731296, heartbeat int. - 60 for connection 82be60ca2edb4f2798322a23429d2bbb
owaisali
kindly if you can guide me i am having this error in windows 10
