Can't Run openvino-workbench on ubuntu
Mostafa-
Hello All,
While trying to run openvino-workbench command line on ubuntu VM, I got the following message;
mostafa@ubuntu:/opt/intel/openvino_2021/deployment_tools/tools/workbench$ openvino-workbench
Could not initialize the Docker client from environment.
Please check if the Docker daemon is running.
and when I checked the service, I found it up and running
mostafa@ubuntu:/opt/intel/openvino_2021/deployment_tools/tools/workbench$ sudo service docker status
● docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2021-11-28 02:44:12 PST; 38min ago
TriggeredBy: ● docker.socket
Docs: https://docs.docker.com
Main PID: 1164 (dockerd)
Tasks: 9
Memory: 112.4M
CGroup: /system.slice/docker.service
└─1164 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
Nov 28 02:44:11 ubuntu dockerd[1164]: time="2021-11-28T02:44:11.131863998-08:00" level=warning msg="Your kernel does not support CPU realtime scheduler"
Nov 28 02:44:11 ubuntu dockerd[1164]: time="2021-11-28T02:44:11.131905835-08:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 28 02:44:11 ubuntu dockerd[1164]: time="2021-11-28T02:44:11.131915126-08:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 28 02:44:11 ubuntu dockerd[1164]: time="2021-11-28T02:44:11.137791401-08:00" level=info msg="Loading containers: start."
Nov 28 02:44:11 ubuntu dockerd[1164]: time="2021-11-28T02:44:11.916565439-08:00" level=info msg="Default bridge (docker0) is assigned with an IP address 172.17.0.0/16. Daemon option --bip can be used to>
Nov 28 02:44:12 ubuntu dockerd[1164]: time="2021-11-28T02:44:12.035313981-08:00" level=info msg="Loading containers: done."
Nov 28 02:44:12 ubuntu dockerd[1164]: time="2021-11-28T02:44:12.801844343-08:00" level=info msg="Docker daemon" commit=e2f740d graphdriver(s)=overlay2 version=20.10.10
Nov 28 02:44:12 ubuntu dockerd[1164]: time="2021-11-28T02:44:12.812532613-08:00" level=info msg="Daemon has completed initialization"
Nov 28 02:44:12 ubuntu systemd[1]: Started Docker Application Container Engine.
Nov 28 02:44:12 ubuntu dockerd[1164]: time="2021-11-28T02:44:12.918399235-08:00" level=info msg="API listen on /run/docker.sock"
Mostafa-
Hi All,
I removed the image and pull it again, and it works.
Thank you,
Mostafa
Mostafa-
Hi All,
Thank you,
Mostafa
Wan_Intel
Hi Mostafa,
Thanks for your question.
This thread will no longer be monitored since this issue has been resolved.
If you need any additional information from Intel, please submit a new question.
Wan
