6592 Discussions
Can we run "python3 stream_infer.py" in VNC environment?
After doing "$ python3 stream_infer.py" in my own Ubuntu 16.04 X64, I have tried to run the command
in VNC server by installing vnc4server in Ubuntu 16.04 X64. However, I have got the below an issue.
How can we run stream_infer.py in VNC server in order to run the command remotely? Anyone that has already experienced?
  • Error messages:
Running USB camera with cheese in VNC environment: Result is Failed.
invain@u1604:~$ cheese (cheese:17167): Gdk-ERROR **: The program 'cheese' received an X Window System error. This probably reflects a bug in the program. The error was 'BadRequest (invalid request code or no such operation)'. (Details: serial 99 error_code 1 request_code 149 (RANDR) minor_code 8) (Note to programmers: normally, X errors are reported asynchronously; that is, you will receive the error a while after causing it. To debug your program, run it with the GDK_SYNCHRONIZE environment variable to change this behavior. You can then get a meaningful backtrace from your debugger if you break on the gdk_x_error() function.) Trace/breakpoint trap (core dumped)
Running stream_infer.py in VNC: Result is Failed.
invain@u1604:/work/ad/movidius/1.07.07/ncapi/py_examples/stream_infer$ python3 stream_infer.py Gtk-Message: Failed to load module "topmenu-gtk-module" Number of categories: 1000 Found stale device, resetting Device 0 Address: 1.6 - VID/PID 03e7:2150 Starting wait for connect with 2000ms timeout Found Address: 1.6 - VID/PID 03e7:2150 Found EP 0x81 : max packet size is 512 bytes Found EP 0x01 : max packet size is 512 bytes Found and opened device Performing bulk write of 825136 bytes... Successfully sent 825136 bytes of data in 34.369671 ms (22.895506 MB/s) Boot successful, device address 1.6 Found Address: 1.6 - VID/PID 040e:f63b done Booted 1.6 -> VSC
hi,
i have more or less the same setup (used vmplayer)
mine didn't work, it starts ok and opens a new window but that stays black (no video stream), i have to close both the camera window & shell to stop it.
i assume it simply can't find the usb camera or driver, haven't checked that yet.
i once got a blue windows screen, but now I unplug/re-plug the mvc between running samples that seems to work ok. (not sure that i the case or it was something completely different)
i tried the other examples.
the one with prediction male/female and age & classifaciton. age seems to work ok.
was funny to see that (by changing the python code so it would look at my own image) my male friend was classified as female
and the classifaction sample told me the image was a book store. (my friend in front of a bookcase) so it recognized the bookcase but not the person in front of it (??)
hope it helps,
regards.
bjorn
hi,
hope it helps,
regards.
bjorn
