Cannot clone repo of openvino
Galati
This issue is since the latest version.
I'm trying in a fresh docker image to add the new pub key from 2021.3
but it fails when i do apt-get update.
Err:9 https://apt.repos.intel.com/openvino/2021 all/main all Packages
File has unexpected size (1427 != 1971). Mirror sync in progress? [IP: xxxx]
Hashes of expected file:
- Filesize:1971 [weak]
- SHA512:df39c515a448f4ac2b237ad5173966adfca45f35ec0f5a6a9100c1b084a9ef9c0702783367be7e649610adc8cf52164ce16ddea922cdffb05423bfa47d297c75
- SHA256:8fbe123b0f278d2e43b4400e275207f73039a29c117f4aab1ecd4675c89e1e1a
- SHA1:13ebe0c19753c20d6604df2cc6ed4808bbf02afa [weak]
- MD5Sum:0aaabfb73da869d5d323aaf7cb92b564 [weak]
Release file created at: Wed, 24 Mar 2021 07:35:16 +0000
Syamimi_Intel
Hi Alex,
Thank you for reaching out. I have validated the installation steps for Intel® Distribution of OpenVINO™ toolkit for Linux distributed through the APT repository, and it is working fine.
I've also validated using a new Docker image and I'm able to run apt-get update successfully.
From your error, it seems that there were some issues during mirror sync. For your information, mirror sync is an update to the mirrors from a central/primary server by copying all the updated files over. During this process, there could be inconsistencies with the latest version.
Please try running the command again, and do come back to us if you face the same error again.
Syamimi
Syamimi_Intel
Hi Alex,
Syamimi
Syamimi_Intel
Hi Alex,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Syamimi Fauzi
