6594 Discussions
Cannot create ShapeOf layer pool10/input_rank/shape_of id:145 when running ./demo_squeezenet_downloa
Zitong-Xu
I'm working on Ubuntu 18.04 with NCS
I followed instructions in Install Intel® Distribution of OpenVINO™ toolkit for Linux*
with version: 2020.3
Here is my dmesg and lsusb results:
which I think the
Myriad VPU [Movidius Neural Compute Stick]
is detected in my system.
However, I came across this problem while running the demo example:
both cmds are not working
sudo ./demo_squeezenet_download_convert_run.sh
sudo ./demo_squeezenet_download_convert_run.sh -d MYRIAD
[ INFO ] Loading network files
[ ERROR ] Cannot create ShapeOf layer pool10/input_rank/shape_of id:145
Error on or near line 217; exiting with status 1
I saw similar problems in the Forums, I thought perhaps because I do not have IE Plugin or IE core in my ubuntu 18.04 system, but I have to use 2020.3 instead of the latest version since I am using NCS.
Could you help me solve this problem? Thanks a lot.
Peh_Intel
Hi Zitong,
The encountered error is due to the mismatch of Intermediate Representation (IR) version and OpenVINO™ version.
I believe that you’ve run the validation demo (demo_squeezenet_download_convert_run.sh) in the later OpenVINO™ version before. Hence, the later model version had been downloaded and converted into IR, and then saved into the /home/<username>/openvino_models directory.
After that, when you run the validation demo in OpenVINO™ 2020.3, the steps of downloading and converting model will be replaced by loading the IR from cache.
Remove the openvino_models folder and re-run the validation demo in OpenVINO™ 2020.3.
Peh
Zitong-Xu
Hello Peh,
Thanks for the quick reply!
I successfully ran the validation demo in OpenVINO 2020.3 after removing the openvino_models directory (yes I had run the 2021.3 version before).
Thanks for your assistance~
Zitong
Peh_Intel
Hi Zitong,
I am glad that I was able to help.
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Peh
