6597 Discussions
Cannot run make all inside caffe to use the examples in ncappzoo
I did successfully installed the ncsdk v2 and did run the examples after running command _make examples_. When I was trying to run the examples on ncappzoo/caffe by running _make all_ command I got into an error stating following.
cpp/run.cpp:125:5: error: ‘mvncStatus’ was not declared in this scope…………..
The attached image have the full error. What could be the solution to this.
Update: Solved I was trying to run v1 examples with v2 ncsdk installed on my host machine.
