6595 Discussions
Coding issue with sample at https://docs.openvino.ai/2023.0/notebooks/230-yolov8-optimization-with-o
MikeVMWEdge
Hello, this sample has a method defined called "post_process" which takes the results of a prediction or segmentation and formats the output.   It leverages a module from ultralytics called ops:
from ultralytics.yolo.utils import ops
and expects a method ops.scale_segments.  It appears that this function does not exist and searching finds no results for it.
---> 62         segments = [ops.scale_segments(input_hw, x, shape, normalize=False) for x in ops.masks2segments(masks)]
     63     results.append({"det": pred[:, :6].numpy(), "segment": segments})
     64 return results
AttributeError: module 'ultralytics.yolo.utils.ops' has no attribute 'scale_segments'
I am looking for tips how to refactor this code to achieve the same results and remove reference to the missing method.   I am new to both ultralytics and openvino.  Any tips?
This should probably be treated as a bug with https://github.com/openvinotoolkit/openvino_notebooks/blob/main/notebooks/230-yolov8-optimization/230-yolov8-optimization.ipynb.  I will log an issue on the repo too.
Iffa_Intel
I don't see that issue from my end. I'm running the code with the function call (scale_segments) using Jupter Notebook on my local machine.
This is my library declaration:
scale_segments function call (it's in the if & else statement of data postprocessing
Test on single image:
Make sure you had set up and installed the requirements properly according to your OS/env.
You may refer here.
Cordially,
Iffa
Iffa_Intel
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
