Combine two YOLO models
Benjamin1
Hi, I am trying to put together two YOLO models to detect different objects. I would like to know if there is a code(in Python)  to do this easily, I am using the object_detection_demo_yolov3_async.py, but it only works for a single model (for example the generic YOLO for 80 classes).
I would also like to know if a YOLO model can be combined with any of the pre-training models from the intel page.
Thanks a lot
Iffa_Intel
Greetings,
This is an example of how to use multiple models in one application:
https://software.intel.com/content/www/us/en/develop/videos/part-6-multiple-models-in-one-application.html
Sincerely,
Iffa
Benjamin1
Hi, thanks :), I had already seen that video, however it does not explain how to do it with python.
Iffa_Intel
That actually depends on which OpenVINO application you are running. It's good if you apply -h to it to see what they support. For instance, the Pedestrian Tracker demo uses two IR models.
You may refer here:
https://docs.openvinotoolkit.org/2018_R5/_samples_pedestrian_tracker_demo_README.html
This should apply to any demos for any language. Again don't forget to use -h command.
Sincerely,
Iffa
Benjamin1
Hi , thanks , which I have to use for two models that detect different objects (for example 2 different yolo models).
I did not find any script that has those requirements.
Iffa_Intel
Actually, if you are just trying to differentiate between two objects you don't need to use two models.
Instead, train the model to differentiate the objects like here:
https://www.youtube.com/watch?v=FaqVhvJ6-Uc
OR
https://www.youtube.com/watch?v=cbdS3BjjbaQ
However, if you are trying to detect text and audio OR detect face, age and gender, then you need to use different models like here:
https://www.youtube.com/watch?v=HEntm0TUqM8
Sincerely,
Iffa
