Compile Deeplab
I’m trying to compile the frozen graph for deeplab from tensorflow models, in particular, the mobilenetv2_coco_voc_trainval variant.
I got the input and output from tensorboard and tried compiling with the following command:
mvNCCompile frozen_graph.pb -s 12 -in=ImageTensor -on SemanticPredictions -is 513 513 -o deeplab.pb
this returned the following error:
shape: (1, ?, ?, 3)
Traceback (most recent call last):
File "/usr/local/bin/mvNCCompile", line 156, in
create_graph(args.network, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights, args.explicit_concat, args.ma2480, args.scheduler, args)
File "/usr/local/bin/mvNCCompile", line 137, in create_graph
load_ret = load_network(args, parser, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 82, in load_network
parse_ret = parse_tensor(arguments, myriad_conf)
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 259, in parse_tensor
input_data = np.random.uniform(0, 1, shape)
File "mtrand.pyx", line 1307, in mtrand.RandomState.uniform
File "mtrand.pyx", line 242, in mtrand.cont2_array_sc
TypeError: index returned non-int (type NoneType)
Thanks for any help
I meet the same problem,Do you solve these problems?
@rosenblat Can you provide a link to the model?
@zhanghanbin3159 Unfortunately at the moment, the NCSDK doesn't have support for semantic image segmentation.
@Tome_at_Intel do you have an ETA of NCSDK support for semantic image segmentation?
