6598 Discussions
Compiling TensorFlow™ Model Zoo Networks
I follow the guidance from https://movidius.github.io/ncsdk/tf_modelzoo.html. to compile Inception v3 Model. However, when I did the step of 'Freeze model for inference', it reports that:
File "/home/stella/tensorflow/tensorflow/python/tools/freeze_graph.py", line 58, in
from tensorflow.python.training import checkpoint_management
ImportError: cannot import name 'checkpoint_management'
I see a similar problem from the forum, the solution is re-cloning the ncappzoo. But I did not make the example from ncappzoo, and I just want to know about the process to compile a tensorflow model of TensorFlow Model Zoo Networks.
How I can solve this problem? I use tensorflow 1.4.0 thx
Hi @Stella2424
I believe the issue is related to the tensorflow version you have installed. I was able to freeze the model using tensorflow version 1.11.0 and the NCSDK v 2.10.01.
Could you try installing these versions?
Jesus
@Jesus_at_Intel Thanks! I install tf 1.11.0, and it worked. And I want to compile the tf model ssd_mobilenet_v1_coco of the zoo. However, when I use the following command to Export GraphDef file,
python3 /home/stella/models/research/slim/export_inference_graph.py \
--alsologtostderr \
--model_name=ssd_mobilenet_v1_coco \
--batch_size=1 \
--dataset_name=imagenet \
--image_size=299 \
--output_file=ssd_mobilenet_v1_coco.pb
File "/home/stella/models/research/slim/export_inference_graph.py", line 156, in
tf.app.run()
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/platform/app.py", line 125, in run
_sys.exit(main(argv))
File "/home/stella/models/research/slim/export_inference_graph.py", line 129, in main
is_training=FLAGS.is_training)
File "/home/stella/models/research/slim/nets/nets_factory.py", line 148, in get_network_fn
raise ValueError('Name of network unknown %s' % name)
ValueError: Name of network unknown ssd_mobilenet_v1_coco
It reports error!
Can you help me compile the ssd_mobilenet_v1_coco model thx!
regards,
