Conflict with protobuf versions
Subtle
I am using  CNNNetwork ReadNetwork(const std::string& model, const Blob::CPtr& weights) function for loading models from memory.
My code looks like:
//vector<uint8_t> model (.xml)
//vector<uint8_t>weights (.bin)
//for creating TensorDesc
InferenceEngine::TensorDesc tensor(InferenceEngine::Precision::U8,{weights.size()}, InferenceEngine::Layout::C);
//For creating Blob
InferenceEngine::TBlob<uint8_t>::Ptr wei_blob = InferenceEngine::make_shared_blob<uint8_t>(tensor,&weights[0],vec_s);
here vec_s is of type size_t
//calling readnetwork
InferenceEngine::CNNNetwork network =  IeCoreSingleton::Instance().ReadNetwork(strModel,wei_blob);
When i am running my code, it is throwing error as below:
[libprotobuf FATAL external/com_google_protobuf/src/google/protobuf/stubs/common.cc:86] This program was compiled against version 3.7.1 of the Protocol Buffer runtime library, which is not compatible with the installed version (3.9.2).  Contact the program author for an update.  If you compiled the program yourself, make sure that your headers are from the same version of Protocol Buffers as your link-time library.  (Version verification failed in "/home/jenkins/agent/workspace/private-ci/ie/build-linux-ubuntu20/b/build/dldt/_deps/ext_onnx-build/onnx/onnx_ngraph_onnx-ml.pb.cc".)
terminate called after throwing an instance of 'google::protobuf::FatalException'
  what():  This program was compiled against version 3.7.1 of the Protocol Buffer runtime library, which is not compatible with the installed version (3.9.2).  Contact the program author for an update.  If you compiled the program yourself, make sure that your headers are from the same version of Protocol Buffers as your link-time library.  (Version verification failed in "/home/jenkins/agent/workspace/private-ci/ie/build-linux-ubuntu20/b/build/dldt/_deps/ext_onnx-build/onnx/onnx_ngraph_onnx-ml.pb.cc".)
Aborted (core dumped)
To solve this error i tried few methods from internet to change the protobuf version including this,
Downloaded the 3.7.1 tarball from https://github.com/protocolbuffers/protobuf/releases
cd protobuf-3.7.1
./configure
make
make check
sudo make install
cd ./python
python3 setup.py build
python3 setup.py test
sudo python3 setup.py install
But It is not resolved. For reference I am using OpenVINO 2021.4 version and OS is Ubuntu 20.04 LTS.
What should i do to resolve this error.
Thanks a lot
Zulkifli_Intel
Hello Subtle
Thank you for reaching out.
The required protobuf version is 3.15.6 as stated in requirements.txt. You can install the specific version using the steps below:
  1. Download the protobuf release here:
    1. https://github.com/protocolbuffers/protobuf/releases/download/v3.15.6/protobuf-all-3.15.6.tar.gz
  2. Unzip the folder
  3. Enter the folder and run ./autogen.sh && ./configure && make
  4. Then run these commands:
make check
sudo make install
Please share with us whether this protobuf version working with your system or not.
Sincerely,
Zulkifli
Zulkifli_Intel
Hello Subtle
  2. Unzip the folder
make check
sudo make install
Sincerely,
Zulkifli
Subtle
Hi Zulkifli_intel,
Thanks for replying.
The issue have been resolved. This conflict was there because of libprotobuf.so.3.7.1.0 file in /opt/intel/openvino_2021/deployment_tools/ngraph/lib folder of openvino installation directory.  I downloaded the protobuf version 3.9.2 and installed on my system. After this i replaced the libprotobuf.so.3.7.1.0 file by libprotobuf.so from ~/protobuf-3.9.2/src/.libs  in /opt/intel/openvino_2021/deployment_tools/ngraph/lib folder. Initialized the OpenVINO environment and my code was working.
I can see libprotobuf.so -> libprotobuf.so.20.0.2 inside ~/protobuf-3.9.2/src/.libs that's why i am able to run my code.
Thank you
Subtle
Zulkifli_Intel
Hi Subtle,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Sincerely,
Zulkifli
