Controlnet with Openvino SD Webui
tuanakotta
Hi there, I have managed to get the A1111 Webui running using the Arc A770 and the OpenVino acceleration script, one issue I am running into is the controlnet extension is completely ignored when I use the custom script, if I leave the script disabled controlnet is used but obviously image generation times are much slower, once I re-enable the script control net is completely ignored even though I can see the generated textures (canny image for example). Any help here would be greatly appreciated as can see in the script controlnet is referenced but I can't seem to find anything related to my issue online.
The controlnet info is even written into PNG info, but the output image is obviously not related to controlnet.
Aznie_Intel
Hi Tuanakotta,
Thanks for reaching out.
Which OpenVINO application are you running? You may check this Text-to-Image Generation with ControlNet Conditioning tutorial in Jupyter Notebook where canny edge detection is one of the target image for the sample.
Hope this helps.
Aznie
tuanakotta
I was using openvino toolkit stable-diffusion-webui for automatic1111. Openvino version 2023.2.0. my interaction with AI image generation was limited to webui because I'm new to this.
Aznie_Intel
Hi Tuanakotta,
Are you using this stable-diffusion-webui repository? If you using the repo, I would suggest you post your query in the thread for better support.
On another note, stable diffusion demos are available in OpenVINO demos. You may check these 3 demos:
Stable Diffusion Text-to-Image Demo
Stable Diffusion v2.1 using Optimum-Intel OpenVINO
Stable Diffusion v2.1 using Optimum-Intel OpenVINO and multiple Intel Hardware
Aznie
Aznie_Intel
Hi Tuanakotta,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
