Hi @Tome_at_Intel
I followed the tutorial of retraining the tensorflow model as mentioned in the blog https://codelabs.developers.google.com/codelabs/tensorflow-for-poets/#0 .
I used the MobileNet model for the retraining.
After retraining I have downloaded the retrained pb file .
When I checked the retraining script was freezing the weights and saving in the pb file so I didnt use the tensorflow freeze script.
Now I tried to convert the pb file to the Movidius graph
mvNCCompile output_graph.pb -in=Placeholder -on=final_result
mvNCCompile v02.00, Copyright @ Intel Corporation 2017
/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py:871: DeprecationWarning: builtin type EagerTensor has no __module__ attribute
/usr/local/lib/python3.5/dist-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead
shape: [1, 224, 224, 3]
[Error 5] Toolkit Error: Stage Details Not Supported: Top Not Found module_apply_default/hub_input/Sub
you can download the pb file from (https://drive.google.com/drive/folders/1FHdCel1abtSa92F88WfRJsbWKxBT3kLV?usp=sharing)
I am able to run the Mobilenet example from the ncappzoo .
I had read in some blogs there is some stage not implemented I this something related to that ? But since I can run Mobilenet from ncappzoo and this also has the same network, so i beleive this should also compile.
- Tags:
- Tensorflow
Hi @Tome_at_Intel
On further investigation in the retrained pb file I found
I converted the pb to pbtxt file and did a grep for "hub_input/Sub"
and found this
node {
op: "Sub"
input: "module_apply_default/hub_input/Mul"
input: "module_apply_default/hub_input/Sub/y"
attr {
key: "T"
value {
type: DT_FLOAT
I think this is not yet implemented in mvNCCCompile .
Because this is missing in the original MobileNet pbtext from google.
Is there any plans of adding this ? Can you provide me some hack around it ?
@deebuls Pete uses some TensorFlow operations that we don't support. A possible alternative would be to use Ashwin's TF Flower retraining project @ https://github.com/ashwinvijayakumar/ncappzoo/tree/flowers/apps/flowers. You will need to update the TF_MODELS_PATH and TF_SRC_PATH in the make file and then run a make train and then make run
