6594 Discussions
Converting OmniScaleNet from PyTorch to Intel IR
Socke__Linux
Is there already something in the model optimizer to convert a self learned OSNet?
SuryaPSC_Intel
Hi Linux,
OSNet is not an OpenVINO pytorch supported topology. Kindly refer to Supported Pytorch* Models via ONNX Conversion.
Surya
SuryaPSC_Intel
Hi Linux,
Surya
Socke__Linux
Ok, thanks.
Can give me some links where I can learn to do it myself then?
Greetings Socke
Max_L_Intel
Hi Socke, Linux
As Surya mentioned above, OSNet is not the one of officially supported topologies. However, you can try to convert this via ONNX conversion if all the model layers are supported by Model Optimizer, as per https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Supported_Frameworks_Layers.html#onnx_supported_operators
and your inference device, as per  https://docs.openvinotoolkit.org/latest/_docs_IE_DG_supported_plugins_Supported_Devices.html#supported_layers
The command is:
python3 mo.py --input_model <INPUT_MODEL>.onnx
Best regards, Max.
