6595 Discussions
Copy net to GPU manually to speed up load network
Nemes__Adam
Hey
I have a relativle small network which loads to the GPU really slowly (more then 20 minutes! )
What can cause such behaviour?
Is there a way to speed this up?
Maybe manually copying the network install give xmlpath or something like this?
Adam
Rizal_Intel
Hi Adam,
Loading your input model in Intermediate Representation (IR) format to GPU takes much longer than loading the same model to a CPU because the GPU stack is based on OpenCL. The load time depends on the compilation time of OpenCL kernels.
You could try to reduce this by enabling cl_cache in the application's directory.
When you enable the cl_cache, the first time you load the model it will still take a long time because the OpenCL kernel will compile. However, each subsequent load of the same model will be much faster. Please ensure that you have write permission at the directory to write the cache.
Read the Optimization Guide GPU Checklist for more information on how to optimize a model for running on a GPU.
Rizal
Rizal_Intel
Hi Adam,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Rizal
