DL Streamer samples - model path error
Kobu_Intel
I can't run DL Streamer samples, e.g.
https://docs.openvinotoolkit.org/latest/_samples_gst_launch_face_detection_and_classification_README.html
Following error occurs:
  Model face-detection-adas-0001 file was not found. Please set MODELS_PATH
Which parameter should be changed in face_detection_and_classification.sh to have program recognize the models path /home/kobu/intel/dl_streamer/models/intel?
# models were successfully downloaded with download_models.sh.
# OpenVINO2020.3 LTS Ubuntu 18.04
It should be easy for experts, sorry for asking this.
Thanks!
BR/Kobu
Max_L_Intel
Hi @Kobu_Intel
Yes, please try new OpenVINO 2020.4 build and during the installation ensure all the components being marked for installation, as per step 3 "If you select the default options, the Installation summary GUI screen looks like this" in https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_linux.html#install-openvino
After this being done, proceed with further steps - install external dependencies, set environment variables, install model optimizer prerequisites, run verification scripts, and then try DL Streamer demo once again.
Best regards, Max.
Kobu_Intel
p.s.:
sudo was used, thanks
$sudo face_detection_and_classification.sh xxxxx(video file or cam device)
Max_L_Intel
Hi @Kobu_Intel
Yes, both download_models.sh and face_detection_and_classification.sh scripts are designed in the way to be used without sudo privileges.
Thanks for using OpenVINO toolkit!
Kobu_Intel
Without sudo, following errors occurred, what is wrong?
My OpenVINO is stable.
./face_detection_and_classification.sh /dev/video0
==> <translation> error pipeline cannot be built: element "v4l2src" is not found
./face_detection_and_classification.sh Running_09_Videvo.mov
==> <translation> error pipeline cannot be built: element "filesrc" is not found
thanks!
BR/Kobu
Max_L_Intel
Hi @Kobu_Intel
1) Did you source bin/setupvars.sh before running the sample?
2) Can you please try to execute it with default input by running the sample script without any parameters
Kobu_Intel
Hi Max,
Thanks for your comments, even default causes error.
<translation> error : pipeline cannot be built: element "urisourcebin" is not found
any suggestion is appreciated.
thanks!
BR/Kobu
Max_L_Intel
Hi @Kobu_Intel
I'm not able to reproduce the issue on my end. For me it works fine on OpenVINO toolkit 2020.3 build under Ubuntu 18.04.
Please install and upgrade (if already installed) all GStreamer related packages with following commands:
sudo apt-get install libgstreamer1.0-0 gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav gstreamer1.0-doc gstreamer1.0-tools gstreamer1.0-x gstreamer1.0-alsa gstreamer1.0-gl gstreamer1.0-gtk3 gstreamer1.0-qt5 gstreamer1.0-pulseaudio
and
sudo apt-get upgrade libgstreamer1.0-0 gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav gstreamer1.0-doc gstreamer1.0-tools gstreamer1.0-x gstreamer1.0-alsa gstreamer1.0-gl gstreamer1.0-gtk3 gstreamer1.0-qt5 gstreamer1.0-pulseaudio
If this doesn't help, then please have a chance to try fresh OpenVINO installation and then run DL Streamer sample again.
Kobu_Intel
Hi @Max_L_Intel
Thanks a lot for your suggestion, 2 commands for Gstreamer were executed.
No error occured (messages in log is Japanese, sorry).
However following error was occurred when running default demo.
<translation> pipeline cannot be built : Element "urisourcebin"  is not found.
I'll try DL Streamer at OpenVINO2020.4, I assume GStreamer & OpenVINO DL Streamer integration my environment is not good. OpenVINO itself is as mentioned very stable.
Thanks!
BR/Kobu
Max_L_Intel
Hi @Kobu_Intel
Best regards, Max.
