DL_Workbench 2021.3
resh
While doing INT8 Calibration getting this error-
What does it specify? Is it that the IR version need to be upgraded? But I am actually using latest 2021.3.9 model optimizer to get the IR.
Attaching model specifications as image for your reference-
Error during INT8 Calibration-
Per-layer Accumulated Metrics
Information on layer runtime precision is not available in this version of the OpenVINO runtime.
Syamimi_Intel
Hi Reshu Singh,
Thank you for reaching out. We would like to know more information about your workaround.
Which model are you use to do the INT8 Calibration ?
Did you follow the steps given in INT8 Calibration ?
For your information, INT8 calibration is not available in the following cases:
  • your configuration uses a generated dataset
  • your configuration uses a model with Intermediate Representation (IR) versions lower than 10
  • your model is already calibrated
  • you run the configuration on an Intel® Processor Graphics, Intel® Movidius™ Neural Compute Stick 2, or Intel® Vision Accelerator Design with Intel® Movidius™ VPUs plugin
Syamimi
resh
Hi @Syamimi_Intel !
The model I am using is my own custom made, not from inbuilt available with OpenVino Toolkit.
For information in the following cases:
  • my configuration uses a custom uploaded dataset -
  • my configuration uses a model with Intermediate Representation (IR) version = 10
  • my model is not already calibrated
  • I am running the configuration on an Intel® Processor
Marat
Dear @resh ,
Thank you for your question.
Seems like you are observing a defect, that is going to be fixed in the upcoming releases. During the calibration of the model the layer analysis information is not available, and of course another message should be shown.
Does the information on layer runtime analysis become available after model is calibrated?
Marat.
resh
The model calibration actually fails and no info related to layer runtime is shown as such.
Marat
So info is not available as calibration failed. Are there any error logs on failed calibration?
resh
Let me share the screenshots of DL Workbench while performing INT8 Calibration [Step By Step]-
Fig 1. IR Loading (FP32 format) to get the metrics on DL Workbench
Fig2: INT8 Calibration over the FP32 IR loaded
Fig3: See Precision Distribution and Precision Transition Matrix Errors below-
Also , for my custom model, I am using 4 inputs for the model , so at the infernce time also I have loaded 4 images to get the metrics. Let me know if any other info is required @Syamimi_Intel , @Marat .
Marat
It would be ideal if you could share the model with us, so we can reproduce and investigate its calibration failure.
If it is not possible, could you provide the log file? For that click settings icon (gear at the right top corner) and download the log file by clicking 'Download Log' button.
resh
Hi @Marat  ,
Attaching the log with this thread-
Please click on the link below-
server_log.txt
Marat
Hi @resh,
According to the logs you have attached calibration failed with the following error:
RuntimeError: IEEngine supports networks with single input or net with 2 inputs. In second case there are image input and image info input Actual inputs number: 4
As you said, you model contains 4 inputs, and more information on inputs is needed for calibration.
In order to calibrate your model you should:
1. Provide annotated dataset;
2. Provide accuracy configuration;
Marat.
resh
Hi @Marat
"RuntimeError: IEEngine supports networks with single input or net with 2 inputs. In second case there are image input and image info input Actual inputs number: 4"
Does it mean that networks with >2 inputs are not handled in IEEngine?
Reshu
Marat
No, this actually means that model with more than 2 inputs cannot be calibrated on not annotated dataset.
If you want to calibrate it you should provide annotated dataset in one of the supported formats and set the accuracy configuration for your model.
Refer to this article on obtaining dataset and this one for accuracy measurement for more information.
resh
Hi @Marat !
Now , I got annotations in COCO JSON format , so my directory has four different folders for four different inputs and one "annotation" folder , which I have zipped and uploaded, Upload is successful and DL Workbench even detects it as "COCO" type. But still INT8 Calib is failing.
Update: I have upgraded DL Workbench version to 2021.4
So , the logs in 2021.4 version are here-
The -result-archive argument is not set. The default value /home/workbench/.workbench/models/1/21/job_artifacts/artifact.tar.gz will be used.
[setupvars.sh] OpenVINO environment initialized
0%| |00:00 0%| |00:00 0%| |00:00Traceback (most recent call last):
File "/usr/local/bin/pot", line 11, in <module>
load_entry_point('pot==1.0', 'console_scripts', 'pot')()
File "/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit/app/run.py", line 36, in main
app(sys.argv[1:])
File "/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit/app/run.py", line 60, in app
metrics = optimize(config)
File "/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit/app/run.py", line 138, in optimize
compressed_model = pipeline.run(model)
File "/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit/compression/pipeline/pipeline.py", line 54, in run
result = self.collect_statistics_and_run(model, current_algo_seq)
File "/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit/compression/pipeline/pipeline.py", line 64, in collect_statistics_and_run
model = algo.run(model)
File "/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit/compression/algorithms/quantization/default/algorithm.py", line 94, in run
self.algorithms[1].algo_collector.compute_statistics(model)
File "/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit/compression/statistics/collector.py", line 70, in compute_statistics
_, stats_ = self._engine.predict(combined_stats, sampler)
File "/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit/compression/engines/ac_engine.py", line 166, in predict
stdout_redirect(self._model_evaluator.process_dataset_async, **args)
File "/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit/compression/utils/logger.py", line 129, in stdout_redirect
res = fn(*args, **kwargs)
File "/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit/libs/open_model_zoo/tools/accuracy_checker/accuracy_checker/evaluators/quantization_model_evaluator.py", line 142, in process_dataset_async
self._fill_free_irs(free_irs, queued_irs, infer_requests_pool, dataset_iterator, **kwargs)
File "/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit/libs/open_model_zoo/tools/accuracy_checker/accuracy_checker/evaluators/quantization_model_evaluator.py", line 329, in _fill_free_irs
batch_input, batch_meta = self._get_batch_input(batch_inputs, batch_annotation)
File "/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit/libs/open_model_zoo/tools/accuracy_checker/accuracy_checker/evaluators/quantization_model_evaluator.py", line 80, in _get_batch_input
filled_inputs = self.input_feeder.fill_inputs(batch_input)
File "/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit/libs/open_model_zoo/tools/accuracy_checker/accuracy_checker/launcher/input_feeder.py", line 193, in fill_inputs
inputs = self.fill_non_constant_inputs(data_representation_batch)
File "/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit/libs/open_model_zoo/tools/accuracy_checker/accuracy_checker/launcher/input_feeder.py", line 165, in fill_non_constant_inputs
'Please provide regular expression for matching in config.'.format(input_layer))
libs.open_model_zoo.tools.accuracy_checker.accuracy_checker.config.config_validator.ConfigError: Impossible to choose correct data for layer depth_input.Please provide regular expression for matching in config.
Can you describe the reason?
Alexander_D_Intel1
Hi @resh,
The first question is whether https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/DL-Workbench-2021-4-Issue/m-p/1296552#M24408 is the same issue or not. To me, it sounds like different issues, correct me if I am wrong.
Regarding your error 'Please provide regular expression for matching in config.'.format(input_layer)), it seems that there are some issues in the accuracy configuration. In particular, it seems that you model has several inputs and one of them is not properly described in the accuracy configuration. Accuracy Checker does not know what data to feed to that input.
Have you tried to measure accuracy before making the calibration? I am afraid you will not be able to make accuracy meausrement as well due to accuracy configuration errors. It will be much easier for you to debug and find the optimal configuration by measuring accuracy. Then you can switch back to the calibration flow and it should work.
Alexander Demidovskij
Syamimi_Intel
Hi Reshu Singh,
I found that you also posted a similar question at case number 05132480. We will treat these as one, please continue further communication at the following 05132480 case.
Syamimi
Syamimi_Intel
Hi Reshu Singh,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Syamimi
