Data layer problem
Vurc
I encounteredproblem when i tried to run provided example human-pose-estimation from python.
On cpu it works, but for MYRIAD it fails with following error
Following layers are not supported by the plugin for specified device MYRIAD: data
Data is the name of input layer and i tried changing it to something else but that also doesnt work.
Best regards.
Shubha_R_Intel
Dear Vurc, I don't see human-pose-estimation as one of the Python samples. The Python samples are located in inference_engine\samples\python_samples and there is no human-pose-estimation in there.
Vurc
Human-pose-estimation is not under python samples, but .pb and IR model are included inside intel_models folder. So it should be able to infer it with python api ?
Vurc.
Shubha_R_Intel
Vurc yes, you should be able to infer those with Python API. Can you kindly post your code here so that we may reproduce ?
