6584 Discussions
DeprecationWarning when using multiprocess (forkserver)
After initialising the process in multiprocess(forkserver) this following message appears.
I tried to do what it says, to change "fromstring" into "frombuffer" in the api… but it doesn't work. With the DeprecationWarning it works OK but I think it should not appear and it should be fixed in the future. I'm using python3.7 on a RaspBerryPi 3B running Debian Stretch.
/opt/movidius/NCSDK/ncsdk-armv7l/api/python/mvnc/mvncapi.py:418: DeprecationWarning: The binary mode of fromstring is deprecated, as it behaves surprisingly on unicode inputs. Use frombuffer instead
tensor = numpy.fromstring(tensor.raw, dtype=numpy.float32)
