Does OpenVINO R2 support NCS2?
Ishida__Ken
I comfirmed NCS2 was active using OpenVINO R1.1 option -d MYRIAD.
But NCS2 isn't active when version is R2 or R3.
It would be load MyriadPuligin.dll.
Does OpenVINO R2 or R3 support NCS2?
Best Regard!
RTasa
Better question is how is Intel supporting edge inferencing with low powered low cost devices
David_C_Intel
Hi Ken,
Thanks for reaching out.
Those OpenVINO™ toolkit versions support the NCS2. However; we recommend using the latest version.
About the Bob T. question, you can check this link for additional information.
David
Ishida__Ken
Thank for your reply.
I checked link site.
But I have read the documentation a lot, but Opnvino R2 and R3 is not working yet.
demo_security_barrier_camera.bat -d MYRIAD option.
Ishida__Ken
Some people have the same problem as me.
It doesn't seem to be solved yet.
Please refer this url.
https://software.intel.com/en-us/forums/intel-distribution-of-openvino-toolkit/topic/829121
David_C_Intel
Hi Ken,
Thank you for your reply.
Could you please answer the following:
 - Which OS version are you using?
 - Could you send the command output?
We tested the demos from our end and they worked successfully using the following:
 - OpenVINO latest version (2019.3.379)
 - Windows 10
 - Python version 3.7.5
 - Command used in the installation folder:
C:Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo>.\demo_security_barrier_camera.bat -d MYRIAD
David
Ishida__Ken
Hi, David,
I use windows OS 10 IoT Enterprise LTSB.  The rev is 1607.
Now I think there is a problem with the OS.
I will confirm openvino using newest windows OS.
Thank you
Ishida__Ken
When I changed newest windows 10 enterprise,
I can confirm demo is active -d MYRIAD .
Thank you!
