6616 Discussions
[Dynamic batch size] Model Resnet50 set dynamic batch size failed!
ke__xu
Hello Sir,
 My Env: Win10, Intel CPU i7(8750H), SDK 2019 R2
 It it run OK for fixed batch size = 2;
 But When it is set to be dynamic batch size, It print failed at run:
   "executable_network = core.LoadNetwork(network, dyn_config);"
 Error log:
   "MKLDNNGraph::CreateGraph: such topology cannot be complied for dynamic batch! Error"
 My Question: Is it not support dynamic batch for Resnet50 model ?
Ke
Shubha_R_Intel
Dear ke, xu,
As the Dynamic Batching Doc says, Dynamic Batching supports only some layers.  My guess is that Resnet50 has some unsupported layers.
Hope it helps,
Shubha
ke__xu
More info:
Log is same with "Dynamic Batching with Face Detection Model"
https://software.intel.com/en-us/forums/computer-vision/topic/808634
Shubha_R_Intel
Dear ke, xu,
Hope it helps,
Shubha
ke__xu
Dear Shubha,
 Thank you very much!
Shubha_R_Intel
Dear Dear ke, xu,
Of course !
Glad to help.
Shubha
Prof_Joshua_Smith
@Shubha_R_Intel Hi,
I couldn't any models supporting dynamic batch sizing, even the example scenario given in the docs doesn't seem working. Is there any possible way we can solve this issue?? It'd great if you could write back.
