6594 Discussions
[ ERROR ] Cannot Init Myriad device: NC_ERROR in function 'initPlugin'
VRudik945
Hi, getting the following error on Pi4
Cannot Init Myriad device;
F: [global] [XXXXXX][Scheduler00Thr] dispatcherLocalEventGetResponse:128 local NACK RTS. stream 'deviceMonitor' is full (event XXXX);
INFO:pedestrianLog:OpenCV(4.2.0-openvino) ../opencv/modules/dnn/src/op_inf_engine.cpp:831: error: (-2:Unspecified error) Failed to initialize Inference Engine backend (device = MYRIAD): Failed to allocate graph: NC_ERROR in function 'initPlugin'
Please advice what does it mean and where should I dig to solve it
Esteban_D_Intel
Hello VRudik945,
I would appreciate if you could confirm the following information:
  • Please provide the model of your Intel device
  • What are the steps to replicate this error message?
Esteban D.
Intel Technical Support Technician
VRudik945
Hello, Esteban.
1) Intel Neural Compute Stick 2
2) Sorry, no idea. It just started to happen on working devices. No signals before happening. Maybe you could at least give ideas where to dig. What could the error mean?
Esteban_D_Intel
Hello VRudik945,
Thank you so much for the clarification.
For your product I would need to route your inquiry to the appropriate support to expedite the resolution of this matter.
If you have any additional concern please let us know.
Esteban D.
Iffa_Intel
Greetings,
Choose the OS according to yours and ensure that you had set up the OpenVINO environment correctly.
Then, follow the additional step for NCS (ensure that you had run setupvars )
You may refer here: https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_windows.html
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
