6594 Discussions
[ERROR] Unsupported layer type : FakeQuantize
lisovoy__andrey
Hi!
I get error:
[ ERROR ] Check (env.config.ignoreUnknownLayers) failed: Failed to compile layer L0008_ActivationBin-back_bone_seq.conv2_2_sep_relubin_bin_conv_BIN01/Quantize_ : Unsupported layer type : FakeQuantize
when run object_detection_sample_ssd example with face-detection-adas-binary-0001 model on NCS2 in docker:
docker run -it -u 0 --device /dev/dri:/dev/dri --device-cgroup-rule='c 189:* rmw' -v /dev/bus/usb:/dev/bus/usb --rm openvino/ubuntu18_dev:latest /bin/bash
cd /tmp
source /opt/intel/openvino/bin/setupvars.sh
cmake -DCMAKE_BUILD_TYPE=Release /opt/intel/openvino/deployment_tools/inference_engine/samples/cpp
make -j2 object_detection_sample_ssd
curl -O https://download.01.org/opencv/2020/openvinotoolkit/2020.1/open_model_zoo/models_bin/1/face-detection-adas-binary-0001/FP32-INT1/face-detection-adas-binary-0001.bin
curl -O https://download.01.org/opencv/2020/openvinotoolkit/2020.1/open_model_zoo/models_bin/1/face-detection-adas-binary-0001/FP32-INT1/face-detection-adas-binary-0001.xml
intel64/Release/object_detection_sample_ssd -m face-detection-adas-binary-0001.xml -d MYRIAD -i /opt/intel/openvino/deployment_tools/open_model_zoo/models/intel/emotions-recognition-retail-0003/description/emotions-recognition-retail-0003.jpg
But face-detection-adas-0001 on MYRIAD and face-detection-adas-binary-0001 on CPU works.
What could be wrong with that?
MAURICIOAL_R_Intel
Thanks for reaching out.
The issue is that you are using a pre-trained model from the open model zoo in FP32-INT1 format. You need to use the FP16 format found here: https://download.01.org/opencv/2020/openvinotoolkit/2020.1/open_model_zoo/models_bin/1/face-detection-adas-0001/FP16/
Mauricio R.
lisovoy__andrey
It is different models, face-detection-adas-0001 and face-detection-adas-binary-0001, accordingly that page:
  • face-detection-adas-0001 - Complexity 2.835 GFLOPs
  • face-detection-adas-binary-0001 - Complexity 0.819 GFLOPs
From here:
The network features a pruned MobileNet backbone...
2.8  GFLOPs are a little bit slow for my project. But when i tryed to use more fast model, i had the problem.
lisovoy__andrey
Took some tests. Seems to MYRIAD can not handle INT models (FP32-INT1, FP32-INT8). Can somebody explain me why?
lisovoy__andrey
Ok, i found answer here:
NCS2  supports FP16 only
MAURICIOAL_R_Intel
Thanks for your response.
We are glad that you found the answer to your query.
Mauricio R.
