6597 Discussions
Empty model blob after compilation and [NOT IMPLEMENTED] Message
nano
Problem Description:
When using the compile_tool to generate a model blob like described here: https://docs.openvinotoolkit.org/latest/openvino_inference_engine_tools_compile_tool_README.html I get an empty blob object and the compile tool returns "[NOT IMPLEMENTED]"
Question:
Do I have to implement something to make the CPU compilation work? Is "CPU" not a valid identificator? What's the problem here?
System:
I tried this on my windows machine using openvino 2020.03 LTS and on my ubuntu machine v18.04 LTS with the newest apt install version.
On the ubuntu machine, using -d MYRIAD option leads to it working, but using -d CPU just returns [NOT IMPLEMENTED]. However I need the model to be compiled for CPUs.
Steps to reproduce for me (fresh installation):
- Download onnx alexnet from https://github.com/onnx/models/blob/master/vision/classification/alexnet/model/bvlcalexnet-8.onnx
- use model optimizer to generate xml and bin file like this: python mo_onnx.py --input_model path_to_onnx\bvlcalexnet-8.onnx --output_dir path_to_out
- run compile_tool -m /path_to_xml/file.xml -d CPU -o /path_to_out/out.blob
Scrollbacks:
After mo_onnx:
Model Optimizer arguments:
Common parameters:
- Path to the Input Model: ...\bvlcalexnet-8.onnx
- Path for generated IR: .../some_path/...
- IR output name: bvlcalexnet-8
- Log level: ERROR
- Batch: Not specified, inherited from the model
- Input layers: Not specified, inherited from the model
- Output layers: Not specified, inherited from the model
- Input shapes: Not specified, inherited from the model
- Mean values: Not specified
- Scale values: Not specified
- Scale factor: Not specified
- Precision of IR: FP32
- Enable fusing: True
- Enable grouped convolutions fusing: True
- Move mean values to preprocess section: False
- Reverse input channels: False
ONNX specific parameters:
Model Optimizer version:
[ SUCCESS ] Generated IR version 10 model.
[ SUCCESS ] XML file: ...\bvlcalexnet-8.xml
[ SUCCESS ] BIN file: ...\bvlcalexnet-8.bin
[ SUCCESS ] Total execution time: 4.00 seconds.
After compile_tool
C:\Program Files (x86)\IntelSWTools\openvino_2020.3.194\deployment_tools\inference_engine\bin\intel64\Release>compile_tool.exe -m D:\path\bvlcalexnet-8.xml -d CPU -o D:\alexnet.blob
Inference Engine:
API version ............ 2.1
Build .................. 2020.3.0-3467-15f2c61a-releases/2020/3
Description ....... API
[NOT_IMPLEMENTED]
Iffa_Intel
Greetings,
Fyi, the compile_tool only supports Myriad, FPGA for now and myriad_compile supports only Myriad.
Documents will be updated accordingly by the developer soon.
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
