6573 Discussions
[Error 15] Toolkit Error: Parser Not Supported: None
When I try to compile some of my own Caffe models I get the error "[Error 15] Toolkit Error: Parser Not Supported: None". What does this mean?
My prototxt file looks like this:
input: "data"
input_shape {
dim: 1
dim: 1
dim: 48
dim: 48
layer {
type: "Convolution"
bottom: "data"
top: "convh0"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 5
stride: 1
weight_filler {
value: 0
bias_filler {
value: 0
layer {
type: "ReLU"
bottom: "convh0"
top: "convh0"
layer {
type: "Pooling"
bottom: "convh0"
top: "poolh0"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "poolh0"
top: "convh1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 5
stride: 1
weight_filler {
value: 0
bias_filler {
value: 0
layer {
type: "ReLU"
bottom: "convh1"
top: "convh1"
layer {
type: "Convolution"
bottom: "convh1"
top: "convh2"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 4
stride: 1
weight_filler {
value: 0
bias_filler {
value: 0
layer {
type: "ReLU"
bottom: "convh2"
top: "convh2"
layer {
type: "InnerProduct"
bottom: "convh2"
top: "fch3"
inner_product_param {
num_output: 1024
weight_filler {
value: 0
bias_filler {
value: 0
layer {
type: "ReLU"
bottom: "fch3"
top: "fch3"
layer {
bottom: "fch3"
top: "y"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
num_output: 38
weight_filler {
value: 0
bias_filler {
value: 0
@graspergazon Hi, which version of the SDK are you using to compile your network? The latest SDK can be found here: https://ncsforum.movidius.com/discussion/98/latest-version-movidius-neural-compute-sdk#latest
I did not have any trouble compiling your prototxt file with the newest sdk using the mvNCCompile command.
Example: $mvNCCompile sample.prototxt -s 12
I am using the latest version of the SDK, cloned from the git repository.
When try mvNCCompile on the original prototxt files I still get Error 15. However, when I copy the contents of a prototxt file to a new file it does compile.
I got the same error report today using freshly installed ncsdk:
parallels@parallels-vm:~/MTCNN/model$ mvNCCompile --version
mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
I was providing .caffemodel instead of .prototxt, so one problem solved.
