6594 Discussions
[Error 17] Toolkit Error: Internal Error: Could not build graph. Missing link: concat
Hi
I'm trying to translate yolov2(darknet) into movidius graph just like what TinyYolov2 in the NCAPPZOO does.(you can see it in the makeflie )
The first step to translate yolo-ibm_40000.weights and yolo-ibm-test.cfg into yolo-ibm-test.pb using "flow" is done.
But when I run mvNCProfile yolo-ibm-test.pb, it returns an error : [Error 17] Toolkit Error: Internal Error: Could not build graph. Missing link: concat
(My mvNC version is v02.00, Copyright @ Movidius Ltd 2016)
I'm a little confused about the error, doesn't ncapi support concat? Could anyone help?
(it seems I can't upload .weights or .cfg, so if you need, for the cfg you can refer to https://github.com/imistyrain/facemask/blob/master/yolo-ibm-test.cfg)
