6594 Discussions
[Error 20] Toolkit Error: Input Layer must be in an input_shape construct.
I've downloaded vgg16 caffe model from this website:
https://gist.github.com/ksimonyan/211839e770f7b538e2d8#file-readme-md
vgg16$ make compile
\nmaking prereqs
(cd ../../data/ilsvrc12; make)
make[1]: Entering directory 'BenchmarkMovidius/examples/data/ilsvrc12'
make[1]: Leaving directory 'BenchmarkMovidius/examples/data/ilsvrc12'
chmod +x run.py
echo "\nmaking prototxt"
\nmaking prototxt
Prototxt file already exists
\nmaking caffemodel
caffemodel file already exists
\nmaking compile
mvNCCompile -w vgg16.caffemodel -s 12 deploy.prototxt
mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
/home/yuepx1027/anaconda2/envs/py3.6/lib/python3.6/site-packages/skimage/init.py:60: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module's documentation for alternative uses
import imp
[libprotobuf WARNING google/protobuf/io/coded_stream.cc:537] Reading dangerously large protocol message. If the message turns out to be larger than 2147483647 bytes, parsing will be halted for security reasons. To increase the limit (or to disable these warnings), see CodedInputStream::SetTotalBytesLimit() in google/protobuf/io/coded_stream.h.
[libprotobuf WARNING google/protobuf/io/coded_stream.cc:78] The total number of bytes read was 553432081
Thanks a lot!
What's the meaning of this Toolkit Error and how can I fix this problem ?
@AaronYue2017 Please visit https://movidius.github.io/ncsdk/Caffe.html and scroll down to the limitation section for more information. We support a specific input format and you just have to modify this networks input to be compatible.
