6593 Discussions
[Error 30] Toolkit Error: Filetype not supported as a input.
I'm trying to compile a custom Tensorflow model into a inference graph but I keep getting this error and I can't find any references here or in the docs into what could be causing it.
Any ideas?
/usr/local/bin/ncsdk/Controllers/Parsers/TensorFlowParser/Convolution.py:44: SyntaxWarning: assertion is always true, perhaps remove parentheses? assert(False, "Layer type not supported by Convolution: " + obj.type) mvNCCompile v02.00, Copyright @ Intel Corporation 2017 /usr/local/lib/python3.5/dist-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead shape: (1, 120, 160, 3) Unsupported [Error 30] Toolkit Error: Filetype not supported as a input.
