6595 Discussions
[Error 5] StridedSlice attributes not supported
Using a custom model according to the specifications in the guide to using custom models throws this error when compiling using mvNCCompile:
[Error 5] Toolkit Error: Stage Details Not Supported: StridedSlice attributes not supported
I suspect this issue is similar to this thread on the unsupported -1 indexing in the Slice op. Can anybody confirm this? Or else tell which attributes the error might refer to otherwise?
Hi , have you solved this problem?
