6589 Discussions
Error: Yolov5 Openvino model run on Raspberry Pi 4 with NCS2
Bendan
Hi all,
I wish to run my best_openvino_model on my Raspberry Pi 4 with NCS2. I exported the openvino model using the official way, and facing error: "requirements: YOLOv5 requirement "openvino" not found" and "No module named "openvino"" as captured in the figure below.
After installing openvino==2021.4.582, I tried the face-detection-adas-0001.xml, and it ran smoothly without error. The version of best.xml generated is in IR 11 format.
Anyone has any idea on this error? Thank you. 
Wan_Intel
Hi Bendan,
OpenVINO™ toolkit version 2021.4.582 does not support IR 11 format. Please use IR 10 format when using OpenVINO™ toolkit version 2021.4.582.
Wan
Bendan
Hi Wan,
Thank you for replying me. However, I tried different ways to convert to IR 10 format, but the output is still in IR 11 format. Can you provide some documentations/resources that convert a Pytorch model into IR 10 format on OpenVINO™ toolkit version 2021.4.582?
Thank you.
Wan_Intel
Hi Bendan,
You may convert your model using OpenVINO™ toolkit version 2021.4. Please refer to Converting a PyTorch Model for more information.
Wan
Bendan
Hi Wan,
Thank you for the information!
Leong Rong Chuan
Wan_Intel
Hi Bendan,
If you need additional information from Intel, please submit a new question as this thread will no longer be monitored.
Best,
Wan
BarryFu
Hi, Bendan
           Could you help me to list the install information such as Raspbian version, the web document which was provided step-by-step method and related packages on Raspberry pi 4? I used  2019-09-26-raspbian-buster, l_openvino_toolkit_runtime_raspbian_p_2021.4.582.tgz and followed the website of https://docs.openvino.ai/2021.4/openvino_docs_install_guides_installing_openvino_raspbian.html
on my Raspberry pi 4 and NCS2. I run openVINO inference with face-detection-adas-0001.xml model unsuccessful.
