Error in GenAI StableDiffusion
Sid007
Hi ,
I am trying to run SDXL Turbo on a VirtualBox VM running Ubuntu 24.04.2 LTS
Host is a Intel Core i5 machine with 8 GB RAM running Windows 10
I have installed openvino and optimum-intel using the pip venv method
pip show openvino ---> 2025.1.0
pip show openvino-genai --> 2025.1.0.0
pip show optimum-intel --> 1.22.0
Also downloaded SDXL Turbo and converted it to IR format using optimum-cli
Now , I am trying to run the following code :-
import openvino_genai as og
from PIL import Image
pipeline=og.Text2ImagePipeline ("sdxl-vino","CPU")
This is giving me the following error :-
RuntimeError :- Check ov_tokenizer || ov_detokenizer
Neither tokenizer nor detokenizer models were provided
Can anyone help or provide a clue as to what is going wrong
Peh_Intel
Hi Sid007,
I was able to run SDXL Turbo model with OpenVINO GenAI.
I am having the same version of openvino, openvino-genai and optimum-intel as you.
The command used before downloading SDXL Turbo model:
pip install diffusers transformers accelerate --upgrade
The command used to download SDXL Turbo model:
optimum-cli export openvino -m stabilityai/sdxl-turbo sdxl-turbo
Hope this helps.
Peh
Peh_Intel
Hi Sid007,
This thread will no longer be monitored since we have provided answer. If you need any additional information from Intel, please submit a new question.
Peh
