Error in building Samples
Verma__Naveen
I have installed openvino in my window PC. Below is the environment variable that I have added.
I have added environment variables.
Inside Path
  • %INTEL_DEV_REDIST%redist\intel64_win\compiler
  • C:\Program Files\CMake\bin
  • C:\ProgramData\Anaconda3\Scripts
  • %INTEL_OPENVINO_DIR%\deployment_tools\inference_engine\bin\intel64\Release
  • %INTEL_OPENVINO_DIR%\deployment_tools\inference_engine\bin\intel64\Debug
  • %HDDL_INSTALL_DIR%\bin
  • %INTEL_OPENVINO_DIR%\openvx\bin
  • C:\Users\user\Documents\Naveen\Projects\build_opencv_contrib_openvino\bin;C:\Users\user\Documents\Naveen\Projects\build_opencv_contrib_openvino\lib
  • %INTEL_OPENVINO_DIR%\opencv\bin
Under system variable
  • INTEL_OPENVINO_DIR -  E:\vino\openvino
  • InferenceEngine_DIR - %INTEL_OPENVINO_DIR%\deployment_tools\inference_engine\share
  • HDDL_INSTALL_DIR - %INTEL_OPENVINO_DIR%\deployment_tools\inference_engine\external\hddl
  • INTEL_CVSDK_DIR - %INTEL_OPENVINO_DIR%
  • PYTHONPATH -     %INTEL_OPENVINO_DIR%\python\python3.7
  • OpenCV_DIR -     %INTEL_OPENVINO_DIR%\opencv\cmake
  • OPENVX_FOLDER - %INTEL_OPENVINO_DIR%\openvx
But when I am trying to build a sample or demo, I am getting a lot of errors. I am attaching the output of cmd below.
E:\vino\openvino\inference_engine\samples>build_samples_msvc.bat VS2015
"vswhere tool is not found"
Creating Visual Studio 14 2015 x64 files in C:\Users\user\Documents\Intel\OpenVINO\inference_engine_samples_build...
-- Selecting Windows SDK version  to target Windows 10.0.18362.
-- Host CPU features:
--   3DNOW not supported
--   3DNOWEXT not supported
--   ABM not supported
--   ADX supported
--   AES supported
--   AVX supported
--   AVX2 supported
--   AVX512CD supported
--   AVX512F supported
--   AVX512ER not supported
--   AVX512PF not supported
--   BMI1 supported
--   BMI2 supported
--   CLFSH supported
--   CMPXCHG16B supported
--   CX8 supported
--   ERMS supported
--   F16C supported
--   FMA supported
--   FSGSBASE supported
--   FXSR supported
--   HLE supported
--   INVPCID supported
--   LAHF supported
--   LZCNT supported
--   MMX supported
--   MMXEXT not supported
--   MONITOR not supported
--   MOVBE supported
--   MSR supported
--   OSXSAVE supported
--   PCLMULQDQ supported
--   POPCNT supported
--   PREFETCHWT1 not supported
--   RDRAND supported
--   RDSEED supported
--   RDTSCP supported
--   RTM supported
--   SEP supported
--   SHA not supported
--   SSE supported
--   SSE2 supported
--   SSE3 supported
--   SSE4.1 supported
--   SSE4.2 supported
--   SSE4a not supported
--   SSSE3 supported
--   SYSCALL supported
--   TBM not supported
--   XOP not supported
--   XSAVE supported
CMake Warning at E:/vino/openvino/deployment_tools/inference_engine/share/InferenceEngineConfig.cmake:30 (message):
  MSVC Compiler doesn't support AVX512 instructuion set
Call Stack (most recent call first):
  E:/vino/openvino/deployment_tools/inference_engine/src/extension/cmake/OptimizationFlags.cmake:64 (ext_message)
  E:/vino/openvino/deployment_tools/inference_engine/src/extension/CMakeLists.txt:55 (set_target_cpu_flags)
-- Configuring done
-- Generating done
-- Build files have been written to: E:/vino/openvino/inference_engine/samples
###############|| Build Inference Engine samples using MS Visual Studio (MSBuild.exe) ||###############
"C:\Program Files (x86)\MSBuild\14.0\Bin\MSBuild.exe" Samples.sln /p:Configuration=Release
Copyright (C) Microsoft Corporation. All rights reserved.
Building the projects in this solution one at a time. To enable parallel build, please add the "/m" switch.
Build started 1/8/2020 12:56:06 PM.
Project "E:\vino\openvino\inference_engine\samples\Samples.sln" on node 1 (default targets).
ValidateSolutionConfiguration:
  Building solution configuration "Release|x64".
ValidateProjects:
  The project "ALL_BUILD" is not selected for building in solution configuration "Release|x64".
The target "CopyLocalFilesOutputGroup" listed in a BeforeTargets attribute at "E:\vcpkg\scripts\buildsystems\msbuild
\vcpkg.targets (84,82)" does not exist in the project, and will be ignored.
Project "E:\vino\openvino\inference_engine\samples\Samples.sln" (1) is building "E:\vino\openvino\inference_engine\s
amples\ZERO_CHECK.vcxproj" (2) on node 1 (default targets).
InitializeBuildStatus:
  Creating "x64\Release\ZERO_CHECK\ZERO_CHECK.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
CustomBuild:
  All outputs are up-to-date.
FinalizeBuildStatus:
  Deleting file "x64\Release\ZERO_CHECK\ZERO_CHECK.tlog\unsuccessfulbuild".
  Touching "x64\Release\ZERO_CHECK\ZERO_CHECK.tlog\ZERO_CHECK.lastbuildstate".
Done Building Project "E:\vino\openvino\inference_engine\samples\ZERO_CHECK.vcxproj" (default targets).
amples\benchmark_app\benchmark_app.vcxproj.metaproj" (3) on node 1 (default targets).
Project "E:\vino\openvino\inference_engine\samples\benchmark_app\benchmark_app.vcxproj.metaproj" (3) is building "E:
\vino\openvino\inference_engine\samples\common\format_reader\format_reader.vcxproj.metaproj" (4) on node 1 (default
targets).
Project "E:\vino\openvino\inference_engine\samples\common\format_reader\format_reader.vcxproj.metaproj" (4) is build
ing "E:\vino\openvino\inference_engine\samples\common\format_reader\format_reader.vcxproj" (5) on node 1 (default ta
rgets).
  Creating "format_reader.dir\Release\format_reader.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
CustomBuild:
VcpkgTripletSelection:
  Using triplet "x64-windows" from "E:\vcpkg\installed\x64-windows\"
ClCompile:
Link:
  format_reader.vcxproj -> E:\vino\openvino\inference_engine\samples\intel64\Release\format_reader.dll
AppLocalFromInstalled:
  C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe -ExecutionPolicy Bypass -noprofile -File "E:\vcpkg\scrip
  ts\buildsystems\msbuild\applocal.ps1" "E:\vino\openvino\inference_engine\samples\intel64\Release\format_reader.dll
  " "E:\vcpkg\installed\x64-windows\bin" "format_reader.dir\Release\format_reader.tlog\format_reader.write.1u.tlog"
  "format_reader.dir\Release\vcpkg.applocal.log"
  Deleting file "format_reader.dir\Release\format_reader.tlog\unsuccessfulbuild".
  Touching "format_reader.dir\Release\format_reader.tlog\format_reader.lastbuildstate".
Done Building Project "E:\vino\openvino\inference_engine\samples\common\format_reader\format_reader.vcxproj" (defaul
t targets).
Done Building Project "E:\vino\openvino\inference_engine\samples\common\format_reader\format_reader.vcxproj.metaproj
\vino\openvino\inference_engine\samples\thirdparty\gflags\gflags_nothreads_static.vcxproj.metaproj" (6) on node 1 (d
efault targets).
Project "E:\vino\openvino\inference_engine\samples\thirdparty\gflags\gflags_nothreads_static.vcxproj.metaproj" (6) i
s building "E:\vino\openvino\inference_engine\samples\thirdparty\gflags\gflags_nothreads_static.vcxproj" (7) on node
C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.CppBuild.targets(392,5): warning MSB8028: The inter
mediate directory (gflags_nothreads_static.dir\Release\) contains files shared from another project (gflags_nothread
s_static.vcxproj).  This can lead to incorrect clean and rebuild behavior.
  Creating "gflags_nothreads_static.dir\Release\gflags_n.E38C0C61.tlog\unsuccessfulbuild" because "AlwaysCreate" was
   specified.
CustomBuild:
ClCompile:
Lib:
  gflags_nothreads_static.vcxproj -> E:\vino\openvino\inference_engine\samples\intel64\Release\gflags_nothreads_stat
  ic.lib
  ts\buildsystems\msbuild\applocal.ps1" "E:\vino\openvino\inference_engine\samples\intel64\Release\gflags_nothreads_
  static.lib" "E:\vcpkg\installed\x64-windows\bin" "gflags_nothreads_static.dir\Release\gflags_n.E38C0C61.tlog\gflag
  s_nothreads_static.write.1u.tlog" "gflags_nothreads_static.dir\Release\vcpkg.applocal.log"
  Deleting file "gflags_nothreads_static.dir\Release\gflags_n.E38C0C61.tlog\unsuccessfulbuild".
  Touching "gflags_nothreads_static.dir\Release\gflags_n.E38C0C61.tlog\gflags_nothreads_static.lastbuildstate".
Done Building Project "E:\vino\openvino\inference_engine\samples\thirdparty\gflags\gflags_nothreads_static.vcxproj"
(default targets).
Done Building Project "E:\vino\openvino\inference_engine\samples\thirdparty\gflags\gflags_nothreads_static.vcxproj.m
etaproj" (default targets).
\vino\openvino\inference_engine\samples\ie_cpu_extension\ie_cpu_extension.vcxproj.metaproj" (8) on node 1 (default t
argets).
Project "E:\vino\openvino\inference_engine\samples\ie_cpu_extension\ie_cpu_extension.vcxproj.metaproj" (8) is buildi
ng "E:\vino\openvino\inference_engine\samples\ie_cpu_extension\ie_cpu_extension.vcxproj" (9) on node 1 (default targ
ets).
  Touching "ie_cpu_extension.dir\Release\ie_cpu_extension.tlog\unsuccessfulbuild".
CustomBuild:
ClCompile:
  C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\CL.exe /c /IE:\vino\openvino\deployment_tools
  \inference_engine\src\extension\PRIVATE /IE:\vino\openvino\deployment_tools\inference_engine\src\extension\common
  /IE:\vino\openvino\deployment_tools\inference_engine\external\tbb\include /IE:\vino\openvino\deployment_tools\infe
  rence_engine\src\extension /IE:\vino\openvino\deployment_tools\inference_engine\include /I"E:\vcpkg\installed\x64-
  windows\include" /nologo /W3 /WX- /O2 /Ob2 /D WIN32 /D _WINDOWS /D _SCL_SECURE_NO_WARNINGS /D NOMINMAX /D NDEBUG /
  D IE_THREAD=IE_THREAD_TBB /D HAVE_SSE /D HAVE_AVX2 /D HAVE_AVX512F /D _CRT_SECURE_NO_WARNINGS /D IMPLEMENT_INFEREN
  CE_ENGINE_API /D "CMAKE_INTDIR=\"Release\"" /D ie_cpu_extension_EXPORTS /D _WINDLL /D _MBCS /Gm- /EHsc /MD /GS /Zc
  :wchar_t /Zc:forScope /Zc:inline /GR /Fo"ie_cpu_extension.dir\Release\\" /Fd"E:\vino\openvino\inference_engine\sam
  ples\intel64\Release\ie_cpu_extension.pdb" /Gd /TP /wd4251 /wd4275 /wd4267 /wd4251 /wd4275 /wd4267 /errorReport:qu
  eue E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_argmax.cpp E:\vino\openvino\deployment_to
  ols\inference_engine\src\extension\ext_base.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\e
  xt_broadcast.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_ctc_greedy.cpp E:\vino\openv
  ino\deployment_tools\inference_engine\src\extension\ext_depth_to_space.cpp E:\vino\openvino\deployment_tools\infer
  ence_engine\src\extension\ext_detectionoutput.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension
  \ext_detectionoutput_onnx.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_fill.cpp E:\vin
  o\openvino\deployment_tools\inference_engine\src\extension\ext_gather.cpp E:\vino\openvino\deployment_tools\infere
  nce_engine\src\extension\ext_gather_tree.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_
  grn.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_interp.cpp E:\vino\openvino\deploymen
  t_tools\inference_engine\src\extension\ext_log_softmax.cpp E:\vino\openvino\deployment_tools\inference_engine\src\
  extension\ext_math.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_mvn.cpp E:\vino\openvi
  no\deployment_tools\inference_engine\src\extension\ext_non_max_suppression.cpp E:\vino\openvino\deployment_tools\i
  nference_engine\src\extension\ext_normalize.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\e
  xt_one_hot.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_pad.cpp E:\vino\openvino\deplo
  yment_tools\inference_engine\src\extension\ext_powerfile.cpp E:\vino\openvino\deployment_tools\inference_engine\sr
  c\extension\ext_priorbox.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_priorbox_cluster
  ed.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_priorgridgenerator_onnx.cpp E:\vino\op
  envino\deployment_tools\inference_engine\src\extension\ext_proposal.cpp E:\vino\openvino\deployment_tools\inferenc
  e_engine\src\extension\ext_proposal_onnx.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_
  psroi.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_range.cpp E:\vino\openvino\deployme
  nt_tools\inference_engine\src\extension\ext_reduce.cpp E:\vino\openvino\deployment_tools\inference_engine\src\exte
  nsion\ext_region_yolo.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_reorg_yolo.cpp E:\v
  ino\openvino\deployment_tools\inference_engine\src\extension\ext_resample.cpp E:\vino\openvino\deployment_tools\in
  ference_engine\src\extension\ext_reverse_sequence.cpp E:\vino\openvino\deployment_tools\inference_engine\src\exten
  sion\ext_roifeatureextractor_onnx.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_scatter
  .cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_select.cpp E:\vino\openvino\deployment_t
  ools\inference_engine\src\extension\ext_shuffle_channels.cpp E:\vino\openvino\deployment_tools\inference_engine\sr
  c\extension\ext_simplernms.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_space_to_depth
  .cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_sparse_fill_empty_rows.cpp E:\vino\openv
  ino\deployment_tools\inference_engine\src\extension\ext_squeeze.cpp E:\vino\openvino\deployment_tools\inference_en
  gine\src\extension\ext_strided_slice.cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_topk
  .cpp E:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_topkrois_onnx.cpp E:\vino\openvino\deplo
  yment_tools\inference_engine\src\extension\ext_unique.cpp E:\vino\openvino\deployment_tools\inference_engine\src\e
  xtension\ext_unsqueeze.cpp
  e:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_base.hpp(46): error C3646: '_mm_uni_loadu_ps':
unknown override specifier
e:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_base.hpp(46): error C2059: syntax error: 'const
e:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_base.hpp(46): error C2334: unexpected token(s)
preceding '{'; skipping apparent function body
e:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_base.hpp(50): error C4430: missing type specifi
er - int assumed. Note: C++ does not support default-int
e:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_base.hpp(50): error C2143: syntax error: missin
g ',' before '&'
e:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_base.hpp(54): error C4430: missing type specifi
e:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_base.hpp(54): error C2146: syntax error: missin
g ')' before identifier 'vec'
e:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_base.hpp(54): error C3646: 'vec': unknown overr
ide specifier
e:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_base.hpp(54): error C2059: syntax error: ')' [E
:\vino\openvino\inference_engine\samples\ie_cpu_extension\ie_cpu_extension.vcxproj]
e:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_base.hpp(58): error C3646: '_mm_uni_setzero_ps'
: unknown override specifier
e:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_base.hpp(58): error C2059: syntax error: ')' [E
e:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_base.hpp(58): error C2334: unexpected token(s)
e:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_base.hpp(62): error C3646: '_mm_uni_set1_ps': u
e:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_base.hpp(62): error C2062: type 'float' unexpec
ted
e:\vino\openvino\deployment_tools\inference_engine\src\extension\ext_base.hpp(62): error C2334: unexpected token(s)
    1 Warning(s)
    4680 Error(s)
Time Elapsed 00:06:05.36
Error
Luis_at_Intel
Hi Naveen,
I am not able to reproduce the issue, the samples built successfully for me using all the same software versions as you.
Done Building Project "C:\Users\user name\Documents\Intel\OpenVINO\inference_engine_samples_build\benchmark_app\ie_samples.vcxproj" (default targets).
Done Building Project "C:\Users\user name\Documents\Intel\OpenVINO\inference_engine_samples_build\benchmark_app\ie_samples.vcxproj.metaproj" (default targets).
Done Building Project "C:\Users\user name\Documents\Intel\OpenVINO\inference_engine_samples_build\Samples.sln" (default targets).
Build succeeded.
"C:\Users\user name\Documents\Intel\OpenVINO\inference_engine_samples_build\Samples.sln" (default target) (1) ->
"C:\Users\user name\Documents\Intel\OpenVINO\inference_engine_samples_build\benchmark_app\benchmark_app.vcxproj.metaproj" (default target) (3) ->
"C:\Users\user name\Documents\Intel\OpenVINO\inference_engine_samples_build\benchmark_app\benchmark_app.vcxproj" (default target) (10) ->
(ClCompile target) ->
  C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\inference_engine\samples\benchmark_app\main.cpp(190): warning C4244: 'argument': conversion from 'double' to 'const float', possible loss of data [C:\Users\user
name\Documents\Intel\OpenVINO\inference_engine_samples_build\benchmark_app\benchmark_app.vcxproj]
  C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\inference_engine\samples\benchmark_app\main.cpp(303): warning C4244: 'argument': conversion from 'double' to 'const float', possible loss of data [C:\Users\user
  C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\inference_engine\samples\benchmark_app\main.cpp(478): warning C4244: 'argument': conversion from 'double' to 'const float', possible loss of data [C:\Users\user
  C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\inference_engine\samples\benchmark_app\main.cpp(484): warning C4244: 'argument': conversion from 'double' to 'const float', possible loss of data [C:\Users\user
  C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\inference_engine\samples\benchmark_app\main.cpp(489): warning C4244: 'argument': conversion from 'double' to 'const float', possible loss of data [C:\Users\user
  C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\inference_engine\samples\benchmark_app\main.cpp(527): warning C4244: 'argument': conversion from 'double' to 'const float', possible loss of data [C:\Users\user
  C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\inference_engine\samples\benchmark_app\main.cpp(529): warning C4244: 'argument': conversion from 'double' to 'const float', possible loss of data [C:\Users\user
  C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\inference_engine\samples\benchmark_app\main.cpp(530): warning C4244: 'argument': conversion from 'double' to 'const float', possible loss of data [C:\Users\user
    8 Warning(s)
    0 Error(s)
Time Elapsed 00:01:21.25
Done.
One thing I noticed in your logs is that your environment supports the AVX512 while mine doesn't, not sure if this is causing problems with MVS 2015. I did some searching and I believe Visual Studio 2017 does support the AVX512 instruction set (while MVS 2015 doesn't), so upgrading Visual Studio* may be an alternative solution here. May I ask which type of CPU do you have?
I could suggest to make sure you installed "MSBuild tools 2015", and all components as mentioned in the MVS 2015 install guide. Please also run the setupvars.bat prior to Configure the Model Optimizer, then attempt to build the samples as you tried with build_samples_msvc.bat VS2015. As an alternative I could suggest trying a a newer version of Visual Studio (2017 or 2019) and see if that resolves the problem, I am inclined to think this would resolve the problem.
Luis
Luis_at_Intel
Hi Verma, Naveen,
It looks like you are trying to setup the OpenVINO™ Toolkit environment variables manually. I am not sure if those are the only variables needed, there may be more missing.
What you could do is try something similar to this. You can run the "set" command on a Command Prompt to see all the environment variables that are already set, capture the output of the command and compare to the "set" command executed after the setupvars.bat is executed. This would give you a pretty good idea as to what files/folders are needed for the demo to build.
Also make sure Python and CMake are added to the Path as mentioned in the documentation here. Let me know if you have any additional questions.
Luis
Verma__Naveen
Hi Luis,
Thanks for the reply,
Initially, I tried running "setupvars.bat " for building samples but I didn't get success. So, I tried setting the environment variable manually.
One more thing that I want to tell you that my PC doesn't have intel GPU.
Below is the output of the "set" command and "setupvars.bat".
E:\vino\openvino\bin>set
ALLUSERSPROFILE=C:\ProgramData
APPDATA=C:\Users\user\AppData\Roaming
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=I2V-SERVER3
ComSpec=C:\WINDOWS\system32\cmd.exe
CONDA_BAT=C:\ProgramData\Anaconda3\condabin\conda.bat
CONDA_EXE=C:\ProgramData\Anaconda3\Scripts\conda.exe
CONDA_SHLVL=0
DriverData=C:\Windows\System32\Drivers\DriverData
GEOSERVER_DATA_DIR=C:\Program Files (x86)\GeoServer 2.15.0\data_dir
GEOSERVER_HOME=C:\Program Files (x86)\GeoServer 2.15.0
HDDL_INSTALL_DIR=E:\vino\openvino\deployment_tools\inference_engine\external\hddl
HOMEDRIVE=C:
HOMEPATH=\Users\user
InferenceEngine_DIR=E:\vino\openvino\deployment_tools\inference_engine\share
INTEL_CVSDK_DIR=E:\vino\openvino
INTEL_DEV_REDIST=C:\Program Files (x86)\Common Files\Intel\Shared Libraries\
INTEL_LICENSE_FILE=C:\Program Files (x86)\Common Files\Intel\Licenses
INTEL_OPENVINO_DIR=E:\vino\openvino
JAVA_HOME=C:\Program Files\Java\jre1.8.0_201
LIB_LICENSING_LIB_DIR=C:\Users\user\Documents\Naveen\opencv\VMS_VA\libraries\cpp_licensing\lib\cmake\liblicensing\
LOCALAPPDATA=C:\Users\user\AppData\Local
LOGONSERVER=\\I2V-SERVER3
MOSQUITTO_DIR=C:\Program Files (x86)\mosquitto
NUMBER_OF_PROCESSORS=16
OneDrive=C:\Users\user\OneDrive
OneDriveConsumer=C:\Users\user\OneDrive
OpenCv_DIR=E:\vino\openvino\opencv\x64\vc14\lib
OPENCV_LIB_DIR=C:\Users\user\Documents\Naveen\Projects\build_opencv_contrib_openvino\lib
OPENVX_FOLDER=E:\vino\openvino\openvx
OS=Windows_NT
Path=C:\ProgramData\Anaconda3\condabin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Users\user\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\MinGW\bin;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files\Microsoft SQL Server\130\DTS\Binn\;C:\Program Files\dotnet\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn\;C:\Program Files\CMake\bin;C:\Program Files\Microsoft\Web Platform Installer\;C:\Program Files (x86)\Microsoft SQL Server\110\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\140\DTS\Binn\;C:\Users\user\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\user\AppData\Local\Programs\Python\Python37\;C:\Users\user\Documents\Naveen\Projects\build_opencv_contrib_openvino\lib;C:\Users\user\Documents\Naveen\Projects\build_opencv_contrib_openvino\bin;E:\vino\openvino\opencv\x64\vc14\bin;E:\vino\openvino\openvx\bin;"E:\vino\openvino\deployment_tools\inference_engine\bin\intel64\Release;E:\vino\openvino\deployment_tools\inference_engine\bin\intel64\Debug;E:\vino\openvino\deployment_tools\inference_engine\external\hddl\bin";C:\Users\user\AppData\Local\Microsoft\WindowsApps;C:\Users\user\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\user\.dotnet\tools;C:\Users\user\AppData\Local\Microsoft\WindowsApps;C:\Users\user\Documents\Naveen\Projects\build_opencv_contrib_openvino\lib\;C:\Users\user\Documents\Naveen\Projects\build_opencv_contrib_openvino\bin\;C:\ProgramData\Anaconda3\Scripts;C:\Users\user\Documents\Naveen\ffmpeg-4.2-win64-static\bin
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 85 Stepping 4, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=5504
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\PowerShell\Modules\
PUBLIC=C:\Users\Public
PYTHONPATH=E:\vino\openvino\deployment_tools\open_model_zoo\tools\accuracy_checker;
RESTBED_LIB_DIR=C:\Users\user\Documents\Naveen\opencv\VMS_VA\libraries\restbed\distribution\lib\cmake\restbed\
ROOT=E:\vino\openvino
SCRIPT_NAME=setupvars.bat
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\Users\user\AppData\Local\Temp
TMP=C:\Users\user\AppData\Local\Temp
USERDOMAIN=I2V-SERVER3
USERDOMAIN_ROAMINGPROFILE=I2V-SERVER3
USERNAME=user
USERPROFILE=C:\Users\user
VA_DIR=C:\Users\user\Documents\Naveen\opencv\VMS_VA\
VCPKG_DEFAULT_TRIPLET=x64-windows
VS110COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\Tools\
VS120COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\Tools\
VS140COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\Tools\
VSSDK140Install=C:\Program Files (x86)\Microsoft Visual Studio 14.0\VSSDK\
windir=C:\WINDOWS
WIX=C:\Program Files (x86)\WiX Toolset v3.11\
E:\vino\openvino\bin>setupvars.bat
Python 3.7.1
ECHO is off.
PYTHONPATH=E:\vino\openvino\deployment_tools\open_model_zoo\tools\accuracy_checker;E:\vino\openvino\python\python3.7;E:\vino\openvino\python\python3;E:\vino\openvino\deployment_tools\open_model_zoo\tools\accuracy_checker;
[setupvars.bat] OpenVINO environment initialized
Luis_at_Intel
Hi Verma, Naveen,
Based on the environment variables, I can see you have multiple versions of MS VisualStudio:
  • VS110COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\Tools\
  • VS120COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\Tools\
  • VS140COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\Tools\
  • VSSDK140Install=C:\Program Files (x86)\Microsoft Visual Studio 14.0\VSSDK
I don't see VisualStudio 15 or later, as mentioned in the requirements page Microsoft Visual Studio* with C++ 2019, 2017, or 2015 with MSBuild is required. May I ask which version of VisualStudio are you using? That may be the reason why you are unable to build the samples successfully.
Please note if you want to use or are already using Microsoft Visual Studio* 2019, CMake 3.14 install is required.
Luis
Verma__Naveen
Hi Luis,
I am using Visual Studio 2015.
Luis_at_Intel
Hi Verma, Naveen,
I will attempt to reproduce the problem by replicating your environment. I now know you have MVS 2015, and I can see Python 3.7.1 from the logs, could you confirm? And also let me know the CMake version you have installed.
Luis
Verma__Naveen
Hi Luis,
Sorry for late reply.
Python - 3.7.1
CMake - 3.14.6
Microsoft Visual studio - 2015
Luis_at_Intel
Hi Naveen,
Build succeeded.
    8 Warning(s)
    0 Error(s)
Done.
Luis
Verma__Naveen
Hi Luis,
Thanks for the support.
Right now, I have only Microsoft Visual Studio 2015. I will follow your instructions and get back to you.
My CPU is - Intel(R) Core(TM) i7-7820X CPU
Verma__Naveen
Hi Luis,
I installed Microsoft Visual Studio 2019 and now I can build demo and samples.
Thanks for your help.
Luis_at_Intel
Hi Naveen,
I am glad the issue was resolved! Don't hesitate to reach back in case you have any questions.
Luis
Jayasekara__Randika
Hello friends,
I'm very new to this, I don't have much skill about software engineering stuff. My major is Electronics and just familiar with Embedded C programming.
Could you please help me to fixed this error, I have got an Error when "Run the Image Classification Verification Script"  (demo_squeezenet_download_convert_run.bat)
My CPU is - Intel(R) Core(TM) i3-2310M CPU @ 2.10GHz and Ram is 6GB
My Installed versions are
  • Python 3.6.5 amd64
  • CMake 3.16.3 -win64 -x64
  • Microsoft Visual studio - 2019 (C++)
  • OpenVino Tool kit 2019.3.379
After in Error happen the "CMakeOutput.log" has been written this
The system is: Windows - 10.0.18362 - AMD64
Inside Path
C:\Users\Randika\AppData\Local\Programs\Python\Python36\Scripts\
%USERPROFILE%\AppData\Local\Microsoft\WindowsApps
C:\Program Files\LLVM\bin
D:\Program Files\Microsoft VS Code\bin
%VS140COMNTOOLS%\VsDevCmd.bat   <- I added this manually after additionally install of VS140 (but result not change)
Under system variable Path
D:\Program Files (x86)\ActiveTd\bin
C:\ProgramData\Oracle\Java\javapath
C:\Program Files (x86)\PC Connectivity Solution\
C:\Program Files\Common Files\Microsoft Shared\Windows Live
C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live
%SystemRoot%\system32
%SystemRoot%
%SystemRoot%\System32\Wbem
%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\
C:\Program Files (x86)\Windows Live\Shared
C:\Program Files\Intel\WiFi\bin\
C:\Program Files\Common Files\Intel\WirelessCommon\
%SYSTEMROOT%\System32\OpenSSH\
D:\Openvino\CMake\bin
Microsoft Windows [Version 10.0.18362.592]
(c) 2019 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>d:
D:\>cd Openvino
D:\Openvino>cd IntelSWTools
D:\Openvino\IntelSWTools>cd openvino
D:\Openvino\IntelSWTools\openvino>cd bin
D:\Openvino\IntelSWTools\openvino\bin>setupvars.bat
Python 3.6.5
ECHO is off.
PYTHONPATH=D:\Openvino\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\accuracy_checker;D:\Openvino\IntelSWTools\openvino\python\python3.6;D:\Openvino\IntelSWTools\openvino\python\python3;
D:\Openvino\IntelSWTools\openvino\bin>cd..
D:\Openvino\IntelSWTools\openvino>cd deployment_tools
D:\Openvino\IntelSWTools\openvino\deployment_tools>cd demo
D:\Openvino\IntelSWTools\openvino\deployment_tools\demo>demo_squeezenet_download_convert_run.bat
target_precision = FP16
Python 3.6.5
ECHO is off.
PYTHONPATH=D:\Openvino\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\accuracy_checker;D:\Openvino\IntelSWTools\openvino\python\python3.6;D:\Openvino\IntelSWTools\openvino\python\python3;D:\Openvino\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\accuracy_checker;D:\Openvino\IntelSWTools\openvino\python\python3.6;D:\Openvino\IntelSWTools\openvino\python\python3;
INTEL_OPENVINO_DIR is set to D:\Openvino\IntelSWTools\openvino
Python 3.6.5
ECHO is off.
Requirement already satisfied: pyyaml in c:\users\randika\appdata\roaming\python\python36\site-packages (from -r D:\Openvino\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 1)) (5.3)
Requirement already satisfied: requests in c:\users\randika\appdata\roaming\python\python36\site-packages (from -r D:\Openvino\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (2.18.4)
Requirement already satisfied: urllib3<1.23,>=1.21.1 in c:\users\randika\appdata\roaming\python\python36\site-packages (from requests->-r D:\Openvino\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (1.22)
Requirement already satisfied: certifi>=2017.4.17 in c:\users\randika\appdata\roaming\python\python36\site-packages (from requests->-r D:\Openvino\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (2019.11.28)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in c:\users\randika\appdata\roaming\python\python36\site-packages (from requests->-r D:\Openvino\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (3.0.4)
Requirement already satisfied: idna<2.7,>=2.5 in c:\users\randika\appdata\roaming\python\python36\site-packages (from requests->-r D:\Openvino\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (2.6)
Download public squeezenet1.1 model
python "D:\Openvino\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\downloader\downloader.py" --name squeezenet1.1 --output_dir C:\Users\Randika\Documents\Intel\OpenVINO\openvino_models\models --cache_dir C:\Users\Randika\Documents\Intel\OpenVINO\openvino_models\cache
################|| Downloading models ||################
========== Retrieving C:\Users\Randika\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.prototxt from the cache
========== Retrieving C:\Users\Randika\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.caffemodel from the cache
################|| Post-processing ||################
========== Replacing text in C:\Users\Randika\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.prototxt
squeezenet1.1 model downloading completed
Waiting for 0 seconds, press a key to continue ...
Target folder C:\Users\Randika\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16 already exists. Skipping IR generation with Model Optimizer.
If you want to convert a model again, remove the entire C:\Users\Randika\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16 folder.
###############|| Generate VS solution for Inference Engine samples using cmake ||###############
'vswhere' is not recognized as an internal or external command,
operable program or batch file.
Creating Visual Studio 14 2015 x64 files in C:\Users\Randika\Documents\Intel\OpenVINO\inference_engine_samples_build...
CMake Error at CMakeLists.txt:7 (project):
  Failed to run MSBuild command:
    C:/Program Files (x86)/MSBuild/14.0/bin/MSBuild.exe
  to get the value of VCTargetsPath:
    Microsoft (R) Build Engine version 14.0.23107.0
    Build started 09/02/2020 15:42:27.
    Project "D:\Openvino\IntelSWTools\openvino\deployment_tools\inference_engine\samples\CMakeFiles\3.16.3\VCTargetsPath.vcxproj" on node 1 (default targets).
    D:\Openvino\IntelSWTools\openvino\deployment_tools\inference_engine\samples\CMakeFiles\3.16.3\VCTargetsPath.vcxproj(14,2): error MSB4019: The imported project "D:\Microsoft.Cpp.Default.props" was not found. Confirm that the path in the <Import> declaration is correct, and that the file exists on disk.
    Done Building Project "D:\Openvino\IntelSWTools\openvino\deployment_tools\inference_engine\samples\CMakeFiles\3.16.3\VCTargetsPath.vcxproj" (default targets) -- FAILED.
    Build FAILED.
    "D:\Openvino\IntelSWTools\openvino\deployment_tools\inference_engine\samples\CMakeFiles\3.16.3\VCTargetsPath.vcxproj" (default target) (1) ->
        0 Warning(s)
        1 Error(s)
    Time Elapsed 00:00:00.07
  Exit code: 1
-- Configuring incomplete, errors occurred!
See also "D:/Openvino/IntelSWTools/openvino/deployment_tools/inference_engine/samples/CMakeFiles/CMakeOutput.log".
Error
Thank You!
Randika
Luis_at_Intel
Hi Jayasekara, Randika,
Based on the information you have provided, Visual Studio* 2019 requires you to install CMake 3.14 (I noticed you have CMake 3.16.3). Also remove the directory "C:\Users\Randika\Documents\Intel\OpenVINO\openvino_models\" and its contents, based on this error:
the toolkit is skipping the IR generation. Once removed, proceed to re-run the demo_squeezenet_download_convert_run.bat script.
If possible try the latest release of OpenVINO (2020.1). Please give this a shot and let us know if the issue persists. For any issues in the future I'd strongly suggest to open a new discussion thread.
Luis
Ajioz
 I have a similar experience but a different CPU base and version.
I am using Intel® Core™ i7-6600U CPU @ 2.60GHz.  I have the latest openVINO installed, VS 2015, and the associated windows SDK 8.1 supported by the VS 2015.
After running the test model I got the following log with errors.  How do I resolve this?
Warm regards
python "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\downloader\downloader.py" --name "squeezenet1.1" --output_dir "C:\Users\hp\Documents\Intel\OpenVINO\openvino_models\models" --cache_dir "C:\Users\hp\Documents\Intel\OpenVINO\openvino_models\cache"
========== Retrieving C:\Users\hp\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.prototxt from the cache
========== Retrieving C:\Users\hp\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.caffemodel from the cache
========== Replacing text in C:\Users\hp\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.prototxt
Target folder C:\Users\hp\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16 already exists. Skipping IR generation with Model Optimizer.
If you want to convert a model again, remove the entire C:\Users\hp\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16 folder.
Creating Visual Studio 14 2015 x64 files in C:\Users\hp\Documents\Intel\OpenVINO\inference_engine_samples_build...
-- Selecting Windows SDK version to target Windows 10.0.18363.
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
No CMAKE_C_COMPILER could be found.
No CMAKE_CXX_COMPILER could be found.
See also "C:/Users/hp/Documents/Intel/OpenVINO/inference_engine_samples_build/CMakeFiles/CMakeOutput.log".
See also "C:/Users/hp/Documents/Intel/OpenVINO/inference_engine_samples_build/CMakeFiles/CMakeError.log".
fikri
please help me i have a problem like this.
i am using CMake 3.21, Visual Studio 2019 with msbuild, python 3.6.5 , OpenVino Tool kit 2021.4.582 and processor AMD A9 7th
###############|| Generate VS solution for Inference Engine demos using cmake ||###############
Creating Visual Studio 16 2019 x64 files in C:\Users\user\Documents\Intel\OpenVINO\inference_engine_demos_build...
-- The C compiler identification is MSVC 19.29.30038.1
-- The CXX compiler identification is MSVC 19.29.30038.1
-- Detecting C compiler ABI info
CMake Error at C:/Program Files/CMake/share/cmake-3.21/Modules/CMakeDetermineCompilerABI.cmake:49 (try_compile):
Failed to open
C:/Users/user/Documents/Intel/OpenVINO/inference_engine_demos_build/CMakeFiles/CMakeTmp/CMakeLists.txt
Permission denied
C:/Program Files/CMake/share/cmake-3.21/Modules/CMakeTestCCompiler.cmake:26 (CMAKE_DETERMINE_COMPILER_ABI)
CMakeLists.txt:16 (project)
-- Detecting C compiler ABI info - failed
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/BuildTools/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe
CMake Error at C:/Program Files/CMake/share/cmake-3.21/Modules/CMakeTestCCompiler.cmake:53 (try_compile):
Failed to open
Permission denied
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/BuildTools/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe - broken
CMake Error at C:/Program Files/CMake/share/cmake-3.21/Modules/CMakeTestCCompiler.cmake:66 (message):
The C compiler
"C:/Program Files (x86)/Microsoft Visual Studio/2019/BuildTools/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe"
is not able to compile a simple test program.
It fails with the following output:
CMake will not be able to correctly generate this project.
See also "C:/Users/user/Documents/Intel/OpenVINO/inference_engine_demos_build/CMakeFiles/CMakeOutput.log".
See also "C:/Users/user/Documents/Intel/OpenVINO/inference_engine_demos_build/CMakeFiles/CMakeError.log".
Error
