6605 Discussions
Error occurs in verification script (demo_squeezenet_download_convert_run.bat)
Kazunori__Kobayashi
The following errors occur.
Building with Visual Studio gives 4689 errors.
####||Build Inference Engine samples using MS Visual Studio||####
7>c:\program files (x86)\intelswtools\openvino_2019.3.379\deployment_tools\inference_engine\src\extension\ext_base.hpp(150): error C2334: '{' の前に予期しないトークンがありました。関数の本体は無視されます
     7>c:\program files (x86)\intelswtools\openvino_2019.3.379\deployment_tools\inference_engine\src\extension\ext_base.hpp(51): error C2065: 'vec': 定義されていない識別子です。
     7>c:\program files (x86)\intelswtools\openvino_2019.3.379\deployment_tools\inference_engine\src\extension\ext_base.hpp(51): error C3861: '_mm512_storeu_ps': 識別子が見つかりませんでした
     7>c:\program files (x86)\intelswtools\openvino_2019.3.379\deployment_tools\inference_engine\src\extension\ext_base.hpp(51): fatal error C1003: プログラム内のエラーが 100 個を超えました。コンパイルは中断されます。
The following processing has already been performed.
setupvars.bat
install_prerequisites.bat
P.S.
OpenVINO toolkit 2019 R3.1
Windows 10
Visual Studio 2015
Python 3.6.5
CMake 3.16.2
JesusE_Intel
Hi Kazunori, Kobayashi,
I had some issues with OpenVINO using Microsoft Visual Studio 2015 and I am having the development team take a look. Could you try to install Microsoft Visual Studio 2019 and CMake version 3.14?
Jesus
Kazunori__Kobayashi
Hi Jesus,
Thank you for your answer.
Please check with the development team.
By the way, if you build the sample code with VS2015,
the following error is displayed:
"__m512 is not defined"
<immintrin.h> is included.
JesusE_Intel
Hi Kobayashi,
I will let you know what I find out. Please let me know the outcome of using Microsoft Visual Studio 2017 or 2019 if you get a chance to try it.
Jesus
