6595 Discussions
Error on Raspberry PI 4 using Intel® Distribution of OpenVINO™ toolkit 2021.2 for Intel NCS2
cesar_diaz_col
Hi!,
I'd like to get some help about this problem using Intel® Distribution of OpenVINO™ toolkit 2021.2 for Intel NCS2 connected to Raspberry PI 4 (raspbian)
When I try to run this code:
https://github.com/glennford49/ObjectDetection_openvino
Models: https://www.mediafire.com/file/o6ecf6txs8p1aui/model.zip/file
Video: https://www.youtube.com/watch?v=kptX-BsDNy0
I had this errors:
from openvino.inference_engine import IENetwork, IECoreModuleNotFoundError: No module named 'openvino'
When I explored the opt/ directory, the armv71 directory doesn't exists.
According to the tutorial, this must be the directory root:
/opt/intel/openvino/python/python3.7/armv7l
What can I do with that?. Thanks!
Peh_Intel
Hi Cesar,
Based on your error, it seems like you didn’t set the environment variables. You can do so with this command:
source /opt/intel/openvino/bin/setupvars.sh
Please refer to the README.md file in the GitHub. The tutorial in the video starts from Step 3 which assuming steps 1 and 2 have been completed.
For steps 1 and 2, you may refer to this installation guide.
After you’ve installed and verified with the demo successfully, you can just easily run the objectDetection.py with this command:
python3 objectDetection.py
Peh
Peh_Intel
Hi Cesar,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Peh
