Error running IR Model on Neural Compute Stick
Bartyzel__Grzegorz
I'm trying to get started with OpenVINO and Neural Compute Stick. For "Hello world" task I chose converting one of my Tensorflow Model to IR Model and run it on NCS. The model is http://download.tensorflow.org/models/object_detection/faster_rcnn_resnet101_coco_2018_01_28.tar.gz (from Tensorflow Model Zoo Object Detection). Of course I'm using it with custom classes and input shape. Compilation to IR Model works like a charm (FP16 and FP32):
python3 mo_tf.py --input_meta_graph ~/train_09_07/model.ckpt-66967.meta --tensorflow_use_custom_operations_config extensions/front/tf/faster_rcnn_support_api_v1.7.json --tensorflow_object_detection_api_pipeline_config ~/train_09_07/pipeline.config --reverse_input_channels --data_type FP32 --batch 1
First for execution I'm using object_detection_sample_ssd from samples delivered with OpenVINO. On CPU execution works. However, when I'm trying to run this on NCS (with model converted to FP16) following error appears:
[ ERROR ] [VPU] Reshape input or output reshape_4d has invalid batch
I was trying to change batch size etc. but nothing works.
I will be grateful for any help.
Greg
Monique_J_Intel
Hi Grzegorz,
Using just the meta graph file isn't enough to convert the model I will reproduce your issue on my side and supply the command line for you to use.
Kind Regards,
Monique Jones
Monique_J_Intel
Hi Grzegorz,
I converted the model with the following command please give it a try:
sudo python3 /opt/intel/computer_vision_sdk/deployment_tools/model_optimizer/mo.py --input_model frozen_inference_graph.pb --tensorflow_object_detection_api_pipeline_config pipeline.config  --output="detection_boxes,detection_scores,num_detections" --tensorflow_use_custom_operations_config /opt/intel/computer_vision_sdk/deployment_tools/model_optimizer/extensions/front/tf/faster_rcnn_support_api_v1.7.json.json
I will try to run it on NCS and see if I get the same error.
Kind Regards,
Monique Jones
Monique_J_Intel
Ok so everything works well on CPU as you saw as well. With the movidius stick i'm getting the following error
[ ERROR ] [VPU] input SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/add has invalid batc
let me take troubleshoot this a bit further and take a look at the graph and see what batch size it's expecting for this layer.
FYI I converted the model again with extra parameters data_type FP16, --batch 1, and --tensorboard_logdir
Kind Regards,
Monique Jones
Garolla__Filippo
Hello, I'm running into the same problem. Was this issue solved?
Berrefas__Thiziri
I tried to convert models mask_rcnn from TensorFlow Object Detection Models Zoo using this command:
mo_tf.py --input_model $ / rcnn_bis / mask_rcnn_resnet101_atrous_coco_2018_01_28 / frozen_inference_graph.pb --tensorflow_use_custom_operations_config /opt/intel/computer_vision_sdk/deployment_tools/model_optimizer/extensions/front/tf/mask_rcnn_support.json --tensorflow_object_detection_api_pipeline_config $ / mask_rcnn_resnet101_atrous_coco_2018_01_28 / pipeline.config - data_type FP16 --batch 1
And I wanted to launch an inference with the following command using an input image of 960 * 525
./mask_rcnn_demo -i $ / blue_car_W_960_H_525.png -m $ / mask_rcnn_resnet101_atrous_coco_2018_01_28 / FP16 / frozen_inference_graph.xml -d MYRIAD
In output I had this error
[ERROR] [VPU] Input SecondStageBoxPredictor_1 / ResizeBilinear has invalid batch
I also converted the rfcn models using this command
mo_tf.py --input_model $ / rfcn_resnet101_coco_2018_01_28 / frozen_inference_graph.pb --tensorflow_use_custom_operations_config /opt/intel/computer_vision_sdk/deployment_tools/model_optimizer/extensions/front/tf/rfcn_support.json --tensorflow_object_detection_api_pipeline_config $ / rfcn_resnet101_coco_2018_01_28 / pipeline.config --data_type FP16 --batch 1
for the inference I used the following command:
./segmentation_demo -i $ / blue_car_W_960_H_525.png -m $ / rfcn_resnet101_coco_2018_01_28 / FP32 / frozen_inference_graph.xml -d MYRIAD
And I had this error
[ERROR] vector :: _ M_range_check: __n (which is 18446744073709551615)> = this-> size () (which is 21)
Can you tell me what to do to fix these errors.
Thanking you in advance.
Thiziri
Shubha_R_Intel
Dear Thiziri:
I'm currently looking into your issues. Sorry that you're having difficulties ! Can you clarify what you mean by this statement ?
Also I have PM'd you, so that you can zip up your frozen.pb and send it to me privately.
Thanks for using OpenVino !
Shubha
Shubha_R_Intel
Dear Thiziri (and everyone):
I encourage you to download the latest release of OpenVino 2019 R1, released today. In this release I see a mask_rcnn_support.json, mask_rcnn_support_api_v1.7.json and mask_rcnn_support_api_v1.11.json.  I also see rfcn_support.json and rfcn_support_api_v1.10.json.  Note that rfcn_support_api_v1.10.json is new in OpenVino 2019 R1. It's important to match up the *.json version number with the Tensorflow API version number. Here is exact wording from the MO Object Detection Online Document:
mask_rcnn_support.json — for frozen Mask R-CNN topologies from the models zoo
mask_rcnn_support_api_v1.7.json — for Mask R-CNN topologies trained manually using the TensorFlow* Object Detection API version 1.7.0 or higher up to 1.9.0 inclusively
mask_rcnn_support_api_v1.11.json — for Mask R-CNN topologies trained manually using the TensorFlow* Object Detection API version 1.10.0 or higher
rfcn_support.json — for the frozen RFCN topology from the models zoo frozen with TensorFlow* version 1.9.0 or lower.
rfcn_support_api_v1.10.json — for the frozen RFCN topology from the models zoo frozen with TensorFlow* version 1.10.0 or higher.
If you follow these rules, model conversion should work. If it still fails however, please feel free to post here and we will help out !
Shubha
Berrefas__Thiziri
Hi Shubha,
Thank you for your help and for the news. I will try again with this information. And I hope it will work!
Thiziri
