6583 Discussions
Error to convert pre-trained tensorflow model to Intel OpenVino IR
YAKNO__MARLINA
I am trying to convert Tensorflow model to Windows 10 OpenVino IR files. I have downloaded a pre-trained model from the following link:
http://download.tensorflow.org/models/object_detection/faster_rcnn_resnet101_coco_2018_01_28.tar.gz
then I used 2 types of commands.
1st command:
(tensorflow_cpu) C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\model_optimizer>python mo_tf.py --input_model="C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\open_model_zoo\models\public\faster_rcnn_resnet101_coco_2018_01_28\frozen_inference_graph.pb" --output=detection_boxes,detection_scores,num_detections --tensorflow_use_custom_operations_config "C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\model_optimizer\extensions\front\tf\faster_rcnn_support.json" --output_dir "C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\open_model_zoo\models\public\faster_rcnn_resnet101_coco_2018_01_28"  --tensorflow_object_detection_api_pipeline_config "C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\open_model_zoo\models\public\faster_rcnn_resnet101_coco_2018_01_28\pipeline.config" --reverse_input_channels
Unfortunately, I got following error message. How I can solve this problem?
1st error:
[ WARNING ] Model Optimizer removes pre-processing block of the model which resizes image keeping aspect ratio. The Inference Engine does not support dynamic image size so the Intermediate Representation file is generated with the input image size of a fixed size.
Specify the "--input_shape" command line parameter to override the default shape which is equal to (600, 600).
The Preprocessor block has been removed. Only nodes performing mean value subtraction and scaling (if applicable) are kept.
The graph output nodes "num_detections", "detection_boxes", "detection_classes", "detection_scores" have been replaced with a single layer of type "Detection Output". Refer to IR catalogue in the documentation for information about this layer.
[ ERROR ]  -------------------------------------------------
[ ERROR ]  ----------------- INTERNAL ERROR ----------------
[ ERROR ]  Unexpected exception happened.
[ ERROR ]  Please contact Model Optimizer developers and forward the following information:
[ ERROR ]  [Errno 13] Permission denied: 'C:\\Program Files (x86)\\IntelSWTools\\openvino_2019.3.379\\deployment_tools\\open_model_zoo\\models\\public\\faster_rcnn_resnet101_coco_2018_01_28\\frozen_inference_graph.bin'
[ ERROR ]  Traceback (most recent call last):
  File "C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\model_optimizer\mo\main.py", line 298, in main
    return driver(argv)
  File "C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\model_optimizer\mo\main.py", line 247, in driver
    is_binary=not argv.input_model_is_text)
  File "C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\model_optimizer\mo\pipeline\tf.py", line 237, in tf2nx
    meta_info=meta_info)
  File "C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\model_optimizer\mo\pipeline\common.py", line 132, in prepare_emit_ir
    serialize_constants(graph, bin_file)
  File "C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\model_optimizer\mo\back\ie_ir_ver_2\emitter.py", line 41, in serialize_constants
    with open(bin_file_name, 'wb') as bin_file:
PermissionError: [Errno 13] Permission denied: 'C:\\Program Files (x86)\\IntelSWTools\\openvino_2019.3.379\\deployment_tools\\open_model_zoo\\models\\public\\faster_rcnn_resnet101_coco_2018_01_28\\frozen_inference_graph.bin'
[ ERROR ]  ---------------- END OF BUG REPORT --------------
2nd command:
(tensorflow_cpu) C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\model_optimizer>python mo_tf.py --input_model="C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\open_model_zoo\models\public\faster_rcnn_resnet101_coco_2018_01_28\frozen_inference_graph.pb" --output=detection_boxes,detection_scores,num_detections --tensorflow_use_custom_operations_config "C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\model_optimizer\extensions\front\tf\faster_rcnn_support_api_v1.7.json" --output_dir "C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\open_model_zoo\models\public\faster_rcnn_resnet101_coco_2018_01_28"  --tensorflow_object_detection_api_pipeline_config "C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\open_model_zoo\models\public\faster_rcnn_resnet101_coco_2018_01_28\pipeline.config" --reverse_input_channels
2nd error:
[ ERROR ]  Failed to match nodes from custom replacement description with id 'ObjectDetectionAPIProposalReplacement':
It means model and custom replacement description are incompatible.
Try to correct custom replacement description according to documentation with respect to model node names
[ ERROR ]  Found the following nodes '[]' with name 'crop_proposals' but there should be exactly 1. Looks like ObjectDetectionAPIProposalReplacement replacement didn't work.
Exception occurred during running replacer "ObjectDetectionAPIDetectionOutputReplacement" (<class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIDetectionOutputReplacement'>): Found the following nodes '[]' with name 'crop_proposals' but there should be exactly 1. Looks like ObjectDetectionAPIProposalReplacement replacement didn't work.
Poca__Ramon
You are trying to write the output graph to a directory where you have no write access.
Either set --output_dir to any other directory (e.g. your desktop) or run the command as administrator.
YAKNO__MARLINA
Hi Poca,
I already tried to change the output directory to D and run it as administrator. Unfortunately, I got another error.
my command:
(tensorflow_cpu) C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\model_optimizer>python mo_tf.py --input_model="C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\open_model_zoo\models\public\faster_rcnn_resnet101_coco_2018_01_28\frozen_inference_graph.pb" --output=detection_boxes,detection_scores,num_detections --tensorflow_use_custom_operations_config "C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\model_optimizer\extensions\front\tf\faster_rcnn_support.json" --output_dir "D:\"  --tensorflow_object_detection_api_pipeline_config "C:\Program Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\open_model_zoo\models\public\faster_rcnn_resnet101_coco_2018_01_28\pipeline.config" --reverse_input_channels
my error:
mo_tf.py: error: unrecognized arguments: Files (x86)\IntelSWTools\openvino_2019.3.379\deployment_tools\open_model_zoo\models\public\faster_rcnn_resnet101_coco_2018_01_28\pipeline.config --reverse_input_channels
Do you have any idea? Thanks in advanced.
SIRIGIRI_V_Intel
Hi YAKNO, MARLINA,
It seems like the issue might be due to a space or new line character in the file path. Please re-run the command by providing the file paths manually, if you are copying them from a document. I have tried to convert the model using all the arguments that you have specified and is working fine.
Ram prasad
