6584 Discussions
Error to make run video_face_matcher in Raspberry Pi 3
ERROR log as below, platform in Raspberry Pi 3 (but the same example able to run in UBUNTU 16.0):
making model
Zip file exists.
Zip file unzipped.
data file exists
index file exists
meta file exists
Converted directory does not exist, doing conversion
model base file name is: facenet_celeb
Traceback (most recent call last):
File "../convert_facenet.py", line 99, in
sys.exit(main())
File "../convert_facenet.py", line 61, in main
prelogits, _ = network.inference(image, 1.0, phase_train=False)
File "/var/ncappzoo/tensorflow/facenet/inception_resnet_v1.py", line 149, in inference
dropout_keep_prob=keep_probability, bottleneck_layer_size=bottleneck_layer_size, reuse=reuse)
File "/var/ncappzoo/tensorflow/facenet/inception_resnet_v1.py", line 207, in inception_resnet_v1
net = slim.repeat(net, 5, block35, scale=0.17)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/contrib/layers/python/layers/layers.py", line 1082, in repeat
outputs = layer(outputs, *args, **kwargs)
File "/var/ncappzoo/tensorflow/facenet/inception_resnet_v1.py", line 42, in block35
mixed = tf.concat([tower_conv, tower_conv1_1, tower_conv2_2], 3)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/ops/array_ops.py", line 867, in concat
dtype=dtypes.int32).get_shape(
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 657, in convert_to_tensor
ret = conversion_func(value, dtype=dtype, name=name, as_ref=as_ref)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/constant_op.py", line 180, in _constant_tensor_conversion_function
return constant(v, dtype=dtype, name=name)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/constant_op.py", line 163, in constant
tensor_util.make_tensor_proto(value, dtype=dtype, shape=shape))
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/tensor_util.py", line 353, in make_tensor_proto
_AssertCompatible(values, dtype)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/tensor_util.py", line 290, in _AssertCompatible
(dtype.name, repr(mismatch), type(mismatch).name))
TypeError: Expected int32, got list containing Tensors of type '_Message' instead.
making compile
/bin/sh: 7: cd: can't cd to 20170512-110547/facenet_celeb_ncs
Command line: mvNCCompile facenet_celeb_ncs.meta -w facenet_celeb_ncs -s 12 -in input -on output -o facenet_celeb_ncs.graph
mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
Please help. Thanks in advanced!
@yockgen The video_face_matcher app uses the TensorFlow model FaceNet. At the moment, we don't have TensorFlow support for the Raspberry Pi yet. Please see the release notes https://github.com/movidius/ncsdk/releases/tag/v1.12.00.01 and scroll down to the Errata section (#2 issue).
